Once Again Fuel Mileage
Old Nov 23, 2005 | 08:46 AM
wittekl's Avatar
Ok so i have a 1995 toyota 4runner 135k 5spd. I just recently got 9.8 mpg, its cold here just over the past week around the low 30's. My egr valve has been throwing a code. i can hear air coming from the modulator for it i believe. When it first starts in the moring its cold. If u mess with the throttle it will stumble, for a minute or so u can get some blue or black smoke. Just wondering if anyone has some input on this thanks. what do u think i should do. I was getting around 15-17 city prior to this cold weather.
Old Nov 23, 2005 | 09:45 AM
bike4miles's Avatar
Holly crap, blue and black smoke hu? I would check your oil for water. Might be a blown head gasket. You should get over 15 mpg, even in 4wd.
Old Nov 23, 2005 | 05:33 PM
wittekl's Avatar
But it doesnt run hot at all and it uses no antifreeze. i did suck water into my motor about 4 months ago. it stalled it out but i did everthing properly and have been getting 15-17mpg after that incident.
Old Nov 24, 2005 | 12:49 AM
wittekl's Avatar
anyone???
Old Nov 24, 2005 | 05:21 AM
sandcrawler's Avatar
well since it started suddenly, and you were getting good MPG prior, it is hard to guess. the blue and BLACK smoke is worrisome. is it a 22re or 3vze? when was the last tuneup? fuel filter? o2 sensor? fuel system cleaning?
Old Nov 24, 2005 | 06:14 AM
Ironmike4x4's Avatar
What code is being thrown by the EGR?
Old Nov 24, 2005 | 07:06 AM
wittekl's Avatar
its the 3.0. i havent personally done a full tuneup , fuel filter, or anythin else to it yet, minus changing every single fluid. i can do almost anything on a car. its throwin code 71 i believe
Old Nov 24, 2005 | 08:58 AM
wittekl's Avatar
it only smokes when it cold out for like 30 seconds then when its warm it runs fine but still bad fuel mileage
Old Nov 24, 2005 | 09:19 AM
kyle_22r's Avatar
black smoke = fuel, blue smoke = oil.
if it's blowing blue smoke on startup or heavy deceleration, it's most likely your valve stem seals.
Old Nov 24, 2005 | 11:43 AM
wittekl's Avatar
egr valve is cold after i drove it for awhile. does this mean its bad??? no smoke today, plugs are fine and i got 13 mpg still i want to try and improve it. any ideas
Old Nov 24, 2005 | 01:27 PM
wittekl's Avatar
oh and its always mostly black smoke, hardly ever the blue smoke
Old Nov 24, 2005 | 04:58 PM
kyle_22r's Avatar
hmm, checked your intake hose between the AFM and the throttle body for leaks or cracks? any air getting in there and not going through the AFM will cause all sorts of wierd problems.
Old Nov 24, 2005 | 08:17 PM
That's what I was wanting to get at, if it's constant black smoke I'm guessing leaky injectors or the computer is dumping more fuel than needed.
edit: I would help diagnose the code itself but I no longer have access to alldata. Do you know what the code description is?
Old Nov 25, 2005 | 10:13 AM
wittekl's Avatar
code 71 is the egr valve, i can get access to alldata , or a scanner if i need to but thats what it was last time i checked it.
Old Nov 28, 2005 | 05:27 AM
Babypig's Avatar
Cold Start Injector?
shisha1999
Sep 21, 2015 08:22 PM
Sep 4, 2015 09:27 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
anniesball
Jul 30, 2015 12:14 PM
