URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
URD SuperGrip Crankshaft Pulley for 3.4L and 3.0L engines
hey guys, check this out --> http://www.urdusa.com/product_info.p..._id=1230100021
It will be a nice mod to add a little extra horses.
Originally Posted by marko3xl3
Works with any 5VZFE. I am gonna get one when I get some money...seems good! Plus it's URD, icing on the cake.
I can't wait to get 5VZFE in my truck, there is so many cool tricks for those motors. So it looks like that may add around 15hp, not bad for $259. That is $17 per pony.
Originally Posted by HUTCHSTACO
how difficult is the install
As long as you have the right tools to pull the pulley and belts, it's very easy. It might be difficult to get the pulley/pulley bolt off the first time, but it's not TOO hard. If you wanna do it yourself...get a Haynes manual or FSM, it's pretty simple. Good Luck.
"As long as you have the right tools to pull the pulley and belts, it's very easy. It might be difficult to get the pulley/pulley bolt off the first time, but it's not TOO hard. If you wanna do it yourself...get a Haynes manual or FSM, it's pretty simple. Good Luck."
How much simpler can I put it? Yes, I was kidding on the top, because you are too lazy to SEARCH for a simple answer to a simple question. Sorry to bring this up AGAIN, but you are asking for it. I put the answer in front of you, I told you it was in front of you, yet you refuse to READ.
/RANT...sorry
/RANT...sorry
i did a search and i thought the small writing was part of your sig, when i did the second post yours right before that didnt show up, ive been haveing that problem alot latley of all the posts not showing up, thank for the real answer.
Originally Posted by TRDOLMAN
I have one sitting on my work bench in my garage. It's purty!!!
I remember seeing a post somewhere with a pic of a homemade tool/bar to hold the crank from turning while loosening and tightening the crank bolt. It was about 4-5 feet long IIRC. The bolt takes a lot of torque, you need a torque wrench that will go up to about 250 ft-lb IIRC.
Trashed the crank and a bunch of other stuff.
Took me nearly 3 days to convince stealer, it was his fault.
Tech had just retorqed pulley with an impact wrench and it fell right off.
Expensive mistake to make on your own truck.
David
Originally Posted by nrgetic99
Had a dealer replace water pump (warranty) and timing belt on my 99 and 3k miles later, the crank pulley fell of !!
David
David
Originally Posted by midiwall
It'll be interesting to see how many folks from the "I don't believe in electric fans" crowd buy these.
I do understand the theory of electric fans (less parasitic drag) but I've read a ton on how people have overheated. I don't want to take a chance with blowing a hg or causing other damage on the motor for the little benefit that this fan would help with. Not to mention, going with a kit like FAL is over $300. This though sounds a lot worthwhile...
I'm still looking for that post with the homemade crank tool but here is an interesting thread: http://www.4x4wire.com/forums/showfl...ev=#Post792689
