URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
Old Nov 17, 2005 | 05:25 PM
yota5VZFE's Avatar
URD SuperGrip Crankshaft Pulley for 3.4L and 3.0L engines
hey guys, check this out --> http://www.urdusa.com/product_info.p..._id=1230100021
It will be a nice mod to add a little extra horses.
Old Nov 17, 2005 | 06:04 PM
marko3xl3's Avatar
Works with any 5VZFE. I am gonna get one when I get some money...seems good! Plus it's URD, icing on the cake.
Old Nov 17, 2005 | 06:12 PM
mtxride's Avatar
let us know how it works out if you get one... i'm always looking for ways to get more power out of the 3.4.
Old Nov 17, 2005 | 06:25 PM
mt_goat's Avatar
I can't wait to get 5VZFE in my truck, there is so many cool tricks for those motors. So it looks like that may add around 15hp, not bad for $259. That is $17 per pony.
Old Nov 17, 2005 | 06:48 PM
HUTCHSTACO's Avatar
how difficult is the install
Old Nov 17, 2005 | 07:09 PM
marko3xl3's Avatar
Extremely hard. You have to use a pseudo-mechanical pulley wrench which costs about $2000 and then buy a plasma pulley puller for another $1500 and even then you can only do it by taking the whole engine out of the truck.
As long as you have the right tools to pull the pulley and belts, it's very easy. It might be difficult to get the pulley/pulley bolt off the first time, but it's not TOO hard. If you wanna do it yourself...get a Haynes manual or FSM, it's pretty simple. Good Luck.
Old Nov 17, 2005 | 07:14 PM
HUTCHSTACO's Avatar
are you joking
Old Nov 17, 2005 | 09:23 PM
marko3xl3's Avatar
are you joking
Yes. Read small print for serious response.
Old Nov 17, 2005 | 09:24 PM
HUTCHSTACO's Avatar
that seems like a joke, i want a pully like that now so i would seriously like an answer to how hard it is to change.
Old Nov 17, 2005 | 09:30 PM
marko3xl3's Avatar
"As long as you have the right tools to pull the pulley and belts, it's very easy. It might be difficult to get the pulley/pulley bolt off the first time, but it's not TOO hard. If you wanna do it yourself...get a Haynes manual or FSM, it's pretty simple. Good Luck."
How much simpler can I put it? Yes, I was kidding on the top, because you are too lazy to SEARCH for a simple answer to a simple question. Sorry to bring this up AGAIN, but you are asking for it. I put the answer in front of you, I told you it was in front of you, yet you refuse to READ.
/RANT...sorry
Old Nov 17, 2005 | 09:37 PM
HUTCHSTACO's Avatar
i did a search and i thought the small writing was part of your sig, when i did the second post yours right before that didnt show up, ive been haveing that problem alot latley of all the posts not showing up, thank for the real answer.
Old Nov 17, 2005 | 09:43 PM
marko3xl3's Avatar
Anytime.
Old Nov 18, 2005 | 03:20 AM
TRDOLMAN's Avatar
I have one sitting on my work bench in my garage. It's purty!!!
Old Nov 18, 2005 | 04:03 AM
MTL_4runner's Avatar
So what are you waiting for Dave, put that sucker on and dyno it so we can all be in awe over your new HP numbers.
Old Nov 18, 2005 | 05:44 AM
mt_goat's Avatar
I remember seeing a post somewhere with a pic of a homemade tool/bar to hold the crank from turning while loosening and tightening the crank bolt. It was about 4-5 feet long IIRC. The bolt takes a lot of torque, you need a torque wrench that will go up to about 250 ft-lb IIRC.
Old Nov 18, 2005 | 05:52 AM
nrgetic99's Avatar
Had a dealer replace water pump (warranty) and timing belt on my 99 and 3k miles later, the crank pulley fell of !!
Trashed the crank and a bunch of other stuff.
Took me nearly 3 days to convince stealer, it was his fault.
Tech had just retorqed pulley with an impact wrench and it fell right off.
Expensive mistake to make on your own truck.
David
Old Nov 18, 2005 | 05:57 AM
midiwall's Avatar
Originally Posted by yota5VZFE
It'll be interesting to see how many folks from the "I don't believe in electric fans" crowd buy these.
Old Nov 18, 2005 | 06:08 AM
mt_goat's Avatar
David
Some of the early 3.4s were coming from the factory with crank bolts that weren't tight enough.
Old Nov 18, 2005 | 06:09 AM
ebelen1's Avatar
Are you talking about me? That's OK because I have been a "Doubting Thomas."
I do understand the theory of electric fans (less parasitic drag) but I've read a ton on how people have overheated. I don't want to take a chance with blowing a hg or causing other damage on the motor for the little benefit that this fan would help with. Not to mention, going with a kit like FAL is over $300. This though sounds a lot worthwhile...
Old Nov 18, 2005 | 06:21 AM
mt_goat's Avatar
I'm still looking for that post with the homemade crank tool but here is an interesting thread: http://www.4x4wire.com/forums/showfl...ev=#Post792689
