URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
Old Dec 21, 2005 | 03:37 PM
  #41
mt_goat's Avatar
Yeah, Chris has kind of scared me away now too.
Old Dec 21, 2005 | 04:15 PM
  #42
vegaskurt's Avatar
Gonna stay away from it. 20hp is not worth having to rebuild the bottom end.
Old Dec 22, 2005 | 08:17 PM
  #43
marko3xl3's Avatar
I am not completely getting this...if anyone could clarify, I'd be grateful.
Basically with an auto transmission you can use this without trouble because the flywheel is so light?
Old Jan 5, 2006 | 11:21 AM
  #44
midiwall's Avatar
Not me... I'm not convinced that having some "flywheel weight" on the crank is such a bad thing.
I understand the concept of how removing weight will help in terms of less mass to overcome under acceleration, but when it comes time to throttle down, then I would think not having the weight there will completely change the ballistics of the engine idling back down - and not in a good way.
For me, this is a lot different than the argument made to remove the mechanical fan. The clutch on the fan disengages on decel anyway...
Old Jan 9, 2006 | 05:42 PM
  #45
yota5VZFE's Avatar
In just 2 more days and this lightened crankshaft pulley will be available for sale to the public. After you installed this pulley on your 3rd Gen., you will get an additional 20 acceleration HP (19.91 HP to be exact). Here is the picture of what it looks like, a very nice anodized red finish:
How many of you in here will be ordering it ?
Old Jan 9, 2006 | 06:27 PM
  #46
HUTCHSTACO's Avatar
i want someone to try it first
Old Jan 10, 2006 | 07:09 PM
  #47
dexter's Avatar
what he said
Old Jan 10, 2006 | 07:50 PM
  #48
Yota4runner's Avatar
Someone is going to have to step up and be the guniea pig. You can post that you want someone to try it as many times as you want but until someone decides they are going to bite the bullet and do it. Its not gonna happen. I'd do it, but I have a 2nd gen.
Christian, has provided a tonne of info pro and con. Read it. and if you have read it again. Then search for more.
Old Jan 10, 2006 | 08:47 PM
  #49
brazos609's Avatar
Urd
I ran a URD pulley on Honda CRX for almost 100,000 miles with no problems. The car had 50,000 miles on it when I bought it and over 150,000 when I sold it. No internal work or any work other than a preventative timing belt change was done, or needed. It ran like a new car till the day I sold it.
Old Jan 10, 2006 | 10:21 PM
  #50
yota5VZFE's Avatar
URD Lightened Crankshaft Pulley for 3.0L and 3.4L
Originally Posted by Yota4runner
Someone is going to have to step up and be the guniea pig. Its not gonna happen. I'd do it, but I have a 2nd gen.
By the way, I looked at the URD website again and they do made a lightened crankshaft pulley for 3.0L (2nd gen). Here is the link and picture: http://www.urdusa.com/product_info.p..._id=1230100022
so, if you have a 2nd gen, you can order one for your 3.0 L too and let us know if you get an increase in performance.
Old Jan 10, 2006 | 10:28 PM
  #51
marko3xl3's Avatar
Uh oh...something's gotta give, lol.
Old Jan 11, 2006 | 03:47 AM
  #52
I have the 22re.
Old Jan 11, 2006 | 04:18 AM
  #53
MTL_4runner's Avatar
I see a few posts in here about the crankshaft pulley being a harmonic balancer, which in the case of the 3.4L and 3.0L it is not.
I actually thought so at first too and disagreed with Gadget that the motors did in fact have a harmonic balancer. With a bit more research I found out that the harmonic balancer on the front is actually just a pulley with a rubber ring to dampen the shock on the driven ascessories. Both the 3.0 and the 3.4 are in fact both internally balanced motors.....this is why the engines are so bullet-proof and they run for 200-300k before a rebuild.
Here is the thread where Gadget and I hashed it all out for your reading pleasure:
https://www.yotatech.com/forums/f2/underdrive-pulley-need-your-opinion-5792/
Old Jan 15, 2006 | 08:21 AM
  #54
mt_goat's Avatar
Originally Posted by mt_goat
I remember seeing a post somewhere with a pic of a homemade tool/bar to hold the crank from turning while loosening and tightening the crank bolt. It was about 4-5 feet long IIRC. The bolt takes a lot of torque, you need a torque wrench that will go up to about 250 ft-lb IIRC.
I finally found the pic: http://www.4x4wire.com/toyota/mainte...elt/tbr_09.jpg
http://www.4x4wire.com/toyota/mainte...elt/tbr_10.jpg
It was part of this write-up:http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old Jan 15, 2006 | 11:11 AM
  #55
midiwall's Avatar
DarylD and I replaced my timing belt a bit ago... when we got to pulling the pulley, Daryl flipped out his trusty chain wrench. With all the rust on my truck, it took a bit of work, but we got the bolt out.
What was worse though is getting the pulley off the shaft - a LOT of prying with crowbars, a bit of finagling with a puller... The shaft was working on becoming an integral part of the pulley.
Old Jan 16, 2006 | 12:05 AM
  #56
Toysrme's Avatar
Cool
All modern Toyota engine's are 100% balanced internally. All Toyota v6's have one of 2 balancing schemes. The vz-fe, 2vz-fe, 3vz-e, 4vz-fe, 5vz-fe, 1mz-fe, 2mz-fe, and 3mz-fe have 5 full coutnerweights on the crankshaft.
The 3vz-fe has 9 semi-counterweights. (Odd-ball of the family LoL!)
Toyota does NOT use balancing weights outside of the engine on any modern engine. All i4's have counter-rotating balance shafts, while I6 & V engines are balanced on the crankshaft.
The engine won't care if it had nothing slung off the end of the crank, or tens of pounds slung off one side. A 20lb lightning on either side is not going to hurt the engine in any way.
Like MTL_4runner pointed out. They are not balancing pulleys to begin with.
There is nothing to be scared of AFA engine damage from the pulleys. I would want to see a dyno before buying. Pulleys & flywheels have a strong tendancy to make little until the very top of the powerband. They grow exponentially, so make sure that's what you want of your powerband.
Old Jul 11, 2006 | 11:20 AM
  #57
Willcipher's Avatar
So has anyone installed one of these yet? I'm suprised nobody has revived this thread yet.
Old Jul 11, 2006 | 11:35 AM
  #58
Allan's Avatar
That extra equipment surely looks suh-weet!!
Good job!!
Old Jul 11, 2006 | 12:41 PM
  #59
mastacox's Avatar
So this pulley essentially helps you put more power to the wheels by slowing down your accessories. The problem I have with this is that your accessories will not work as well at low rpms, such as your power steering, AC compressor, or alternator. I would prefer to keep all of my accessories running at full speed, to help with battery charging, steering effort, and AC coldness...
Old Jul 11, 2006 | 01:02 PM
  #60
ilikesoup's Avatar
Is anyone running one of these yet. From what i've read about how the engine is totally interanlly balanced, it shouldn't matter what the heck is hanging off each end. No harmonic balancers...
What kind of performance gains are we looking at? this mod isn't THAT expensive, and the red looks pretty badass
