Replace gaskets when changing diff / txfer case oil!
Old Dec 10, 2009 | 07:24 AM
stir_fry_boy's Avatar
Well, I got underneath my truck to help the guy lube my driveline and make sure he got all the zerks. I saw that my txfer case was leaking, out the drain plug. It was tight but when I switched over to AMSOIL Severe Gear 75w-90 I didn't buy new metal gaskets. I guess I learned my lesson. GET NEW GASKETS! They are cheap, and definetly not worth the $13 / qt it is to have it leak and change it again. I thought it would be ok to not buy the gaskets. Guess what I will be doing tomorrow? Changing the txfer case oil along with a regular oil change, tranny fluid drain and fill and rear diff drain and fill.
Just thought I might help out fellow YTers.
Pics to come tomorrow.
Old Apr 20, 2010 | 11:03 AM
wjamyers's Avatar
Whatever happened to this? Do you mean "crush washers" rather than "gaskets"?
Old Apr 20, 2010 | 12:35 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
yup- pretty sure he meant crush washers (i did this when i did the maintenance 2 years ago.)
Old Apr 20, 2010 | 12:46 PM
badattitude's Avatar
Those crush washers are not reuseable. I wondered if they would actually leak if not replaced. Now I know, they do. I keep a few on hand after changing the rear diff oil. It's more of a hassle to go them than it is a cost issue.
Old Apr 20, 2010 | 12:59 PM
crolison's Avatar
Mine never had, and i've gotten into the rear axle a lot
Old Apr 20, 2010 | 01:11 PM
brian2sun's Avatar
You can flip the crush washers around a couple of times. I've changed out my diff and t-case fluid a couple of times and haven't replaced my washers. I just flipped them and no leaks, tranny too.
Old Apr 21, 2010 | 10:10 AM
Some are crush washers, some are metal gaskets. The metal gaskets are solid all the way around. The crush washers are separated into 2 pieces if you view it from the top of the ring looking down onto the side. I think that it is cheap insurance to just replace them. All 6 cost me around $6. My motto is: Do it once, do it right and never have to worry about it.
P51warrior
Jun 25, 2015 05:50 AM
toy89yota
Jun 24, 2015 01:18 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
HBoss
Dec 20, 2004 08:45 AM
