3rd gen rear brake question
Old Nov 21, 2009 | 05:07 PM
Kerby J's Avatar
i know that there are kits available out there that allow you to change your rear drums to disk but is there any way that the late model tundra rear disk brakes might b able to be retrofitted in some way or are they to big bc the tundra has 18" wheels stock?
Old Nov 22, 2009 | 03:07 PM
Kerby J's Avatar
anyone have any input
Old Nov 22, 2009 | 03:18 PM
Elton's Avatar
what year tundra ?
Old Nov 22, 2009 | 10:14 PM
Kerby J's Avatar
like an '09 i saw one the other day and noticed that it had rear disks but i also know they come with 18's stock which makes me wonder if there too big or will fit a 16" wheel
Old Nov 22, 2009 | 11:27 PM
Elton's Avatar
you do know there 5 lug ? all you might be able to use is the calipers
Old Nov 23, 2009 | 07:24 AM
Kerby J's Avatar
o didnt know that well i guess it wouldnt work then o well
Old Nov 23, 2009 | 07:38 AM
pkt1213's Avatar
Do the 4th gen 4runners have rear disks?
Old Nov 23, 2009 | 10:31 AM
Elton's Avatar
i believe they do
Old Nov 24, 2009 | 04:05 PM
pkt1213's Avatar
I'm thinking that a 4th gen 4runner might be a better place to start. The Tundra had leaf spring rear suspension. I am assuming that it's an 8" Toyota and you could use an e-locker on it.
Old Nov 24, 2009 | 04:34 PM
crolison's Avatar
Using old chevy calipers you can get rear disks with ebrake
http://www.sky-manufacturing.com/new...uct.php?id=128
Old Nov 26, 2009 | 08:04 AM
Kerby J's Avatar
i would rather stick to all toyota if possible but sometime u jus have to use inferior parts haha
Old Nov 26, 2009 | 08:54 AM
YotaFun's Avatar
The 4th gen 4Runners have the e-brake separate to the caliper.
It would be awesome to get the system to work, but it might be a bit much.
I am actually thinking myself to go with the chevy calipers.
I use to be all Toyota, but if it works it works.
Heck, I have a filter originally designed for a ford filtering the oil in my Toyota.
Good luck with your final decision...
Old Dec 6, 2009 | 05:56 PM
sn22's Avatar
I just did the Tundra front brake upgrade on my '97, man what a differance!! That being said I am going to convert the rears to disc using brackets and the stock toyota front calipers and rotors. I hope to do this the beginning of January. Has anybody else done this?
Old Dec 6, 2009 | 06:16 PM
nah2323's Avatar
Double post....
Old Dec 6, 2009 | 06:19 PM
nah2323's Avatar
Vented rears? hmm. It would be cool if it worked, might be a little overkill, and because they are a two piston caliper, the brake proportioning valve maybe be no good, so you may need to switch to an adjustable.
Old Dec 6, 2009 | 07:16 PM
Kerby J's Avatar
also what do you plan on doing about the e-break bc there arnt any kits for our transfer case
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
Steezy96yota
Jul 6, 2015 10:00 AM
coryc85
Jul 6, 2015 04:07 AM
