Squealing from alt belt!
Old Nov 12, 2009 | 02:35 AM
awpsome's Avatar
i just replaced my alt with a new HO alt was running fine for a couple hours then i noticed when i would touch the accelerator a bit it would start to squeak. most accelerator i pushed the faster it got. but funny thing is if im nothing pushing accelerator i doesnt squeal..
wth is going on?
was working good after the alt went in now i tried to tighten it somemore.
but now what the happened..
I BROKE THE SCREW... what do i do now?
am i ed? the screw cracked right down the middle. i guess cause its old and probably worn down but now what?
should i still drive on it?
please no flaming i just need some help and small vent. but i really wantto fix this asap.
thank you
Old Nov 12, 2009 | 03:11 AM
crolison's Avatar
Is the bolt that locks the alternator at that point tight? Is the alternator have any movement?
I broke the adjustment screw on one of my ex's volvo's so I just pulled it as tight as a I could by hand and tightened the set bolt.
Old Nov 12, 2009 | 04:20 AM
Team420's Avatar
what year, motor, type of rig?
If its the 3.0, did u break the bottom adjusting bolt? Or the top bolt? If u broke the top bolt, get a new one, if the bottom, pull tight, and tighten that top bolt to hold it put. I broke the bottom bolt on mine a year ago, and the top bolt has been holding it just fine. I am glad this thread came up tho, cuz I completely forgot about it till now, and should prolly be fixed.
Old Nov 12, 2009 | 10:45 AM
awpsome's Avatar
it's a 97 3.4L v6
I'll try to get photos
but the adjuste screw on the bottom snapped in two
top bolt is tight but not tight enough to hold the tension
the set screw for the bottom is still in tact but now in going to need a friend to help me set it if I have to pull it...
in a way I still want to fix it... make it tight cause the squealing is killing me...
why did it all of a sudden start to squeal though? from my previous alt to couple hours on my new alt it was fine..
Old Nov 12, 2009 | 03:11 PM
awpsome's Avatar
got a new bolt will update when I'm done and let you guys know on squealing
thanks everyone
Old Nov 12, 2009 | 03:15 PM
Kiroshu's Avatar
Yea just make sure its tight and don't kill her.
Old Dec 1, 2009 | 10:43 PM
xjsqared's Avatar
Hopefully you fixed your broken bolt.....I think my alternator is going, it has a slight squeal when the lights are on, if I load up the the piaa driving lights and headlights and radio, I can hear it even more when at idle, I cant really notice when driving, am I just paranoid? It does have 275,000 I would like to replace it with a new alternator, where can I find a H.O. ?
Old Dec 2, 2009 | 12:12 AM
awpsome's Avatar
plenty places to find a H.O. depends what appliucation your planning to use it on.
and yes i replaced the bolt everything is BEAUTIFUL now.
the alt puts out really good voltage and keeps it all stable.
btw alt squeal came from an off alignment of belt. HAHA fixed that real fast with just moving the belt over one groove.. oops.. HAHA
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
