02 sensor replacement - 01 TACO Dbl Cab
Old Nov 14, 2009 | 12:22 PM
Baloo's Avatar
I got busy (a little lazy too) and took my 2001 Dbl Cab in to have my Magnaflow muffler reinstalled, an hour or so job. 3 days later when I get the truck back I get going down the road and about a mile I throw a P0141.
Of course the installer tells me anytime you mess with the 02 you risk this happening however since they clamped rather then welded it I am not sure why the had to remove it and the pipe.
Anyway, my question is: The culprit is the sensor AFTER the CAT. Taking a quick look in the lot I see the wires go up into the body through a grommet in the underside body. Is the plig right on the other side of that grommet? Do I remove the whole grommet or just work the wires through it in place.
Lesson learned; whenever possible, DO IT YOURSELF?
Old Nov 14, 2009 | 03:21 PM
hurricanes99's Avatar
Not sure about the Taco, but on my 99 4Runner there is a plug about a foot up from the sensor. I ordered one and should be replacing mine in the next few days. I don't think you should have to go all the way into the interior to replace it.
Old Nov 15, 2009 | 11:50 AM
mt_goat's Avatar
On the 01 Taco ext-cab I had the plug to the rear sensor is under the carpet. IIRC I just removed the passinger side door sill trim and lifted up the carpet and found it. Can't remember if I removed the grommet or just worked the plug through it.
Old Nov 15, 2009 | 12:32 PM
Baloo's Avatar
Thanks. The part hadn't come in yet so wasn't sure how long the pigtail would be, Was trying to decide if I was going to do it or insist they pay for me to have someone else do it after my experience.
I think it will be the former so I know it is done right.
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
karbin
Jul 5, 2015 11:37 PM
elwood73
Jul 5, 2015 07:07 AM
