mod to clear 15" wheel
Old Nov 22, 2009 | 05:18 PM
cpizzle42's Avatar
I love 15" wheels and wanted them on my current '96 runner. So I took some material off my calipers to clear the 15 steel wheels. I used a grinder and slowly grinded the caliper down till the wheel no longer hit. Why? Wheels are cheap. Tires are REALLY cheap. More tire to air down with. And I like the look of a 15". Here are a few pics.
My rig on 35" BFG KM2's...And no body lift. Just many hours of work.
Old Nov 22, 2009 | 05:38 PM
98runner210's Avatar
man grinding a caliper down to me sounds like such a bad idea.
Old Nov 22, 2009 | 05:51 PM
cpizzle42's Avatar
I do kinda agree with you. I took a risk when I did it, and was not sure what the outcome would be. Since then I have towed trailers up and down mountains and stopped big tires for about 15,000 miles, and I have had no problems at all.
Old Nov 22, 2009 | 07:02 PM
b0n3mast3r's Avatar
that is a no no to me safety com first
Old Nov 22, 2009 | 07:09 PM
camo31_10.50's Avatar
safety comes first huh....i think spelling and proper sentence structure should come before that my friend..LOL..
of course i can already tell my sentence structure sucks as well..HAHAHA..i love your rig though CPizzle
Old Nov 22, 2009 | 09:28 PM
cpizzle42's Avatar
I agree, that is why I am designing a roll cage....
Thank you! I love her too!
Old Nov 23, 2009 | 12:57 PM
Cal01's Avatar
even with a 4" bs, you still need to grind?
there shouldn't be no issue from the grind. i'd do it
Old Nov 23, 2009 | 02:28 PM
akaphilly's Avatar
damn i run a 1.5 inch wheel spacer and my 15's still dont fit! any before and after pics on the grinding?
Old Nov 23, 2009 | 05:20 PM
cpizzle42's Avatar
I believe the back spacing is -15.
Yeah I am a firm believer that wheel spacers are not safe. Some would probably call me a hypocrite for saying that. But at work we are so against wheel spacers, I guess I am now too personally.
Sorry I tried google image search for stock caliper and couldnt find a good pic.
Old Mar 28, 2011 | 05:58 PM
Datsayota's Avatar
Cpizzle,
I've got the ss 1.2 front and rear & I'm planning on doing the same as you, make the 35's fit without any more lift. Also I'm with you on the 15" wheels as the better choice.
Did I read correctly that you are running a 15X8? Isn't that a little narrow for those 35's?
And what back spacing do those wheels have, 4"?
Old Mar 29, 2011 | 02:01 PM
cpizzle42's Avatar
Originally Posted by Datsayota
Cpizzle,
I am running the 15x8's so the tires are less likely to come off the bead when aired down. I forget the backspacing, but that sounds about right.
Old Mar 29, 2011 | 02:20 PM
corax's Avatar
It all depends on how much you take off. There should be enough leeway in the casting to allow a decent amount, though I wouldn't go more than 1/8" without pulling a piston to measure the actual thickness.
Old Mar 29, 2011 | 10:21 PM
wyoming9's Avatar
Red face
If you have caliper problems will you just rebuild yours.
Talking to my auto parts vendors they all said the cores would be rejected .
I had thought of doing that myself but passed. To many Lawyers with nothing to do.
Old Mar 30, 2011 | 12:40 AM
traxxi2003's Avatar
Hey cpizzle42, Can you post more pictures of the calipers? I recently did the same thing on my rig. And would like to compare my calipers with yours, to see how much material you grind off of your calipers. Thanks!
Old Mar 30, 2011 | 09:36 PM
cpizzle42's Avatar
Too many lawyers with nothing to do? You can say that about anything.
I did this at 194k and now have over 214K. I think I ll be alright man.
And why would I need new calipers? I would just rebuild the ones I have if the seals on the pistons went bad.
Old Mar 30, 2011 | 09:39 PM
cpizzle42's Avatar
Not sure what anlge of picture would better show how much I took off. Not trying to sound rude, but really just take off as little as possible, assuming you went with the correct offset. I probably took off around .075-.100
Old Mar 31, 2011 | 01:12 AM
traxxi2003's Avatar
Well, my wheels have 3.75" BS. If I stop a little hard I'll get a temporary caliper rubbing while applying the brakes (only when stoping hard). Otherwise no rub at all.
Jun 1, 2021 01:51 PM
Rasteirinho
Nov 6, 2017 03:40 AM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
