99 vsv sensor number.
Old Dec 11, 2009 | 02:55 PM
Eat_at_Joes's Avatar
I am in the middle of a 3.4 engine swap and im missing the vsv sensor. this sensor needs to be on the vacuum system to run right and i cant track one down to save my life. I went to toyota and they have 2 sensor part numbers come up and i dont know witch i need or if it even matters.
The sensors are spendy and i only want to have to buy one. does anybody have a 99 tacoma manual 4x4 that they could get me the number from or offer me some help. i tried junkyards and still cant find one.
The sensor should have only one vacuum line going to it and a conector with three wires. located next to the canistor on the driver side fender.
Thanks
Old Dec 11, 2009 | 06:58 PM
KZN185W's Avatar
do you have a pic so i can check it? or if you have the 2 part numbers, post it so we can see which one is applicable. is your truck a VZN160L or a VZN170L?
Old Dec 11, 2009 | 07:46 PM
i dont have the vin to the truck that the ecu and harness came off of but the numbers that i got for the vsv sensor are 89460-04010 and 89460-35030. these are the numbers straight from toyota. The sensor is actually bassically sitting on top of the master cylinder on the firewall with only a small metal bracket holding it.
Old Dec 12, 2009 | 01:59 AM
KZN185W's Avatar
it's known as the Vapor Pressure Sensor Assembly and it seems that the correct part number is 89460-04010.
jb451
7
Oct 7, 2022 06:58 AM
Bourbonblues
Dec 15, 2017 05:43 PM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
