new differential gears breaking-in
Old Dec 7, 2009 | 12:32 AM
KZN185W's Avatar
Hi, Is there a breaking-in procedure that needs to be done if new differential gears are installed? is there a need for a special oil to be used? Thanks!
Old Dec 7, 2009 | 12:34 AM
Elton's Avatar
https://www.yotatech.com/forums/f2/g...ocedure-12588/
Old Dec 7, 2009 | 04:59 AM
mt_goat's Avatar
Yes very important to not over heat the gears. When new, the gear mating surfaces are rough and heat up quicky. If they get too hot it ruins the heat treatment of the gears and they will then wear out faster. I also change the oil often during the break-in.
Old Dec 8, 2009 | 01:18 AM
KZN185W's Avatar
Thank you guys! Appreciate it!
Old Dec 8, 2009 | 02:29 AM
Just Learning's Avatar
ok this brings up a ?what type /weight of oil do you use- i use 85-140, what effect does this have??
i have new lockers and just drove them , yes i did change out the gear oil about 500 miles and i just did it now (trying to figure out how to do the transfer case)
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gevo
Jul 29, 2015 11:15 AM
Athansinis
Jul 27, 2015 08:38 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
