Radiator hose clamps ?
Old Dec 15, 2009 | 09:45 PM
alotawatts's Avatar
I'm partial to using / replacing the factory type radiator hose clamps that don't have the worm /screw bolt for tightening but rather are just a compression/stretch fit. I worry less about the plastic radiator necks cracking etc.
On the other hand the screw type band/clamp should'nt give at all with temperature changes and the factory types could be just a 'quicker line assembly' type thing.
Thoughts ?
thx
Old Dec 16, 2009 | 06:48 AM
eric-the-red's Avatar
I've never replaced the original factory hose clamps on either of my 4Runners. They were reused after hose and/or radiator replacement and I've never had any leaks.
Old Dec 16, 2009 | 07:27 AM
Yukon's Avatar
The clamp that holds the bottom radiator hose on got pulled off once off roading, causing massive fluid loss, and overheating. Made for an interesting evening.
Old Dec 16, 2009 | 07:37 AM
Qyota's Avatar
The screw-type are tighter, but they can tend to lacerate the rubber hoses if installed too tightly, or just from normal vibration and wear. I'd like to see a screw-type clamp with rolled edges to prevent this.
I'd just re-use the stockers, unless they are too corroded or otherwise weakened.
Old Dec 16, 2009 | 07:56 AM
hross14's Avatar
I too would love to find a supplier that has hose clamps that DO NOT cut the hose........
AND--Quality electrical connectors
Old Dec 16, 2009 | 10:38 AM
OrRunner's Avatar
dealer can get the clamps for about 5.00 each
Old Dec 17, 2009 | 01:48 AM
alotawatts's Avatar
Thanks for the replies.
Now here's mine-
BMW hose clamps do not shred rubber......smooth ribs.
Can be sourced via autohausaz, carpartstogo etc...
Old Sep 29, 2020 | 02:48 PM
nottoshabi's Avatar
5 Year Member
My coolant expansion tank is busted on my 78. Have you guys had to change yours?
Old Sep 30, 2020 | 08:41 AM
Marc's Avatar
Might be better to post this in the 78 forum.
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
gmonnie123
Jul 26, 2015 02:44 PM
jjrbus
Jul 19, 2015 02:06 PM
Poncho0206
Jul 10, 2015 06:21 PM
