license plate bolt sheared off
Old Dec 1, 2009 | 11:17 AM
gilby4runner's Avatar
I had to get new tags today and when i went to replace my plate both of the bolts sheared off. (yes i did use PB blaster). I removed the rear hatch panel to see if i could get to them but it would be rather difficult. They are rather rusty and dirty. They broke flush with the panel. Options or recomendations?
Old Dec 1, 2009 | 11:23 AM
bgmac's Avatar
Drill them out! Thats what I had to do. Then get a bolt and put a nut w/ locking washer on the back. There is just enough room to reach your had back there to put the nut/washer on.
Old Dec 1, 2009 | 11:25 AM
i was afraid that was what i was going to do...
Thanks bgmac
Old Dec 1, 2009 | 11:30 AM
bgmac's Avatar
Its not as bad as it seems. Note***make sure your back window is up when drilling! Lol
Old Dec 1, 2009 | 01:44 PM
For those who might have the same issue... here are a few options
1. "Easy Out" or similar bolt / screw remover. (I tried one but the bolts were just to rusted.
2. Drill out the sheared bolts and replace with new bolts and nylon nuts or lock washers on the back side.
**If you have big hands you will have to be patient. The top right bolt is a pain! I taped two wrenches together and tried that approach. It would worked but my patience wore thin.
Old Dec 1, 2009 | 04:51 PM
LK1's Avatar
LK1
Double sided foam tape?
Old Dec 1, 2009 | 05:11 PM
camo31_10.50's Avatar
use screws...?? instead of bolts? maybe...thread the holes?
Old Dec 2, 2009 | 07:19 AM
gpcollen1's Avatar
Why would you not just drill and tap them and install new bolts. Pretty simple really...
smithyboy69
Nov 28, 2015 04:13 PM
RobotMoose
Sep 2, 2015 05:53 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Snort
Jul 9, 2015 03:58 PM
