Cold air or throttle body spacer
Old Dec 12, 2009 | 10:31 AM
yamaboy03's Avatar
Question Cold air or throttle body spacer
I have an 02 prerunner 2.7 ltr. I wanna enhance the get up on it. What would be best to go with first, a cold air intake or a throttle body spacer. I have no concern with gas mileage, just more power. Any comments would help
Old Dec 12, 2009 | 10:38 AM
Teuf's Avatar
Start with a Cam, Header, Exhaust, ,stock K&N, I see very little to no gain with the 2 you mentioned.
Old Dec 12, 2009 | 10:44 AM
yamaboy03's Avatar
As of right now i have a drop in k n filter in stock airbox and flowmaster 40 series. I just cannot seem to find a header for my truck. I mainly see ones for 3.4 ltr. Does it make a difference what brand cam you buy?
Old Dec 12, 2009 | 10:49 AM
Teuf's Avatar
It may, try LcEngineering for starts, i have had good luck with them. And post a signature on your truck stats.
Old Dec 12, 2009 | 11:06 AM
Van Cour's Avatar
throttle body spacer will give low end response your throttle with be more sensitive.
Old Dec 12, 2009 | 11:14 AM
yamaboy03's Avatar
Would a cold air make a big difference vs. The k&n drop in filter?
Old Dec 12, 2009 | 11:20 AM
mt_goat's Avatar
If you experenced that, it was probably the throttle cable getting adjusted tighter.
Old Dec 12, 2009 | 12:16 PM
Teuf's Avatar
I did the TB spacer, money wasted.
Old Dec 12, 2009 | 12:19 PM
toyota4x4907's Avatar
Buy a mini-header from DeathCougar. Fixes the cracked manifold issue and its a header
Old Dec 12, 2009 | 12:25 PM
yamaboy03's Avatar
Originally Posted by teuf
i did the tb spacer, money wasted.
so what your saying is dont waste my money on a tb spacer?
Old Dec 12, 2009 | 12:27 PM
yamaboy03's Avatar
Originally Posted by toyota4x4907
buy a mini-header from deathcougar. Fixes the cracked manifold issue and its a header :d
so if i get the header from death cougar, will it enhance the performance on my truck or will it have the characteristics of a stock header?
Old Dec 12, 2009 | 12:28 PM
its somewhat of a performance enhancer, AFAIK.
Old Dec 12, 2009 | 12:30 PM
Elton's Avatar
fancy k&n intakes are a waste of money tb spacers are junk and dont work
Old Dec 12, 2009 | 12:52 PM
Teuf's Avatar
I just think money could be better spent on something other than a TB spacer. If i started over i would have done gears n lockers first , then foo foo engine mods.
Old Dec 12, 2009 | 12:57 PM
mt_goat's Avatar
Originally Posted by Teuf
... If i started over i would have done gears n lockers first , then foo foo engine mods.
Smart man Hind sight is 20/20.
Old Dec 12, 2009 | 01:09 PM
Teuf's Avatar
So true.
Old Dec 12, 2009 | 01:26 PM
Van Cour's Avatar
well its abigger dif on a 3.4
Old Dec 12, 2009 | 01:36 PM
yamaboy03's Avatar
yeah very true, but u can only get so much out of a 2.7 ltr..
Old Dec 13, 2009 | 06:19 AM
j-man's Avatar
turbo it and youll see 300 hp to the wheels. go over to customtacos.com and start looking around. the 2.7 is sooo easy to turbo.
Old Dec 13, 2009 | 08:12 AM
mt_goat's Avatar
X2, here's a guy over on CT (Paradise Racing) that built a 1200 HP 2RZFE 2.4 Tacoma engine and has many drag runs to prove it. One run was 7.21 sec @192mph !!!
Some pics of his stuff: http://customtacos.com/forum/showthread.php?t=101710
Website: http://paradiseracing.com/Store/
