timing marks not lining up
Old Dec 18, 2020 | 12:59 PM
ptf1496's Avatar
hey guys, im in the process of changing my timing belt/ water pump. ive taken the tensioner and new belt off twice because everytime i line the PULLY (not belt) marks up with the marks on the engine and put the belt on, i put the tensioner back on then rotate the crank and the marks on the crank line up but the marks on the camshaft pulleys are slightly off. Is this a Problem that the two camshaft pulley marks arnt perfectly aligned with the marks on the rear timing cover ? i dont want to start this thing up and ruin all the valves. i also need to get this thing back on the road because i need a 4x4 to get to work in the winter months. Any help is greatly appreciated. attatched are pics of the upper pulleys after the crank has been rotated and the cranks is online with its mark
Old Dec 19, 2020 | 06:43 AM
moto809's Avatar
5 Year Member
The timing marks on the belt are for initial install only. Once the crank is rotated the marks will no longer line up with the cam marks.
Old Dec 19, 2020 | 06:50 AM
ptf1496's Avatar
even the camshaft pulley marks wont line up with the marks on the timing cover after it rotates? Thanks
Old Dec 19, 2020 | 06:51 AM
moto809's Avatar
5 Year Member
Initial install should look like this...
Old Dec 19, 2020 | 07:14 AM
moto809's Avatar
5 Year Member
Correct. Initial timing is the only time you worry about the marks on the belt.
Old Dec 19, 2020 | 08:54 AM
millball's Avatar
The marks on the pulleys themselves should ALWAYS register correctly.
Old Dec 19, 2020 | 07:53 PM
moto809's Avatar
5 Year Member
Absolutely correct. My bad, I read the question wrong.
Old Dec 20, 2020 | 02:24 PM
ptf1496's Avatar
Thanks everyone, i just didnt have the belt taught over the teeth before releasing the tensioner. It was a struggle but i got it all aligned nice and tight. Released the tensioner, rotated the crank and everything was good. Gonna finish putting her back together tomorrow and shell be ready for work on tuesday. Thanks again!
Old Dec 21, 2020 | 10:50 AM
ptf1496's Avatar
after a few mishaps with fuel return lines and vaccum hoses, (L0L) i got everything on right. i threw some new fuel injectors in there while the manifold was off and even with a small vacuum hiss, it runs way smoother than it did before. gonna fix that hiss later along with a few bolts i didnt put back on because they were basically unusable either from someone else previously stripping them or being flatout rusted. besides that, runs awesome! thanks again everyone, shes ready (enough) for work tomorrow
Old Jan 12, 2021 | 04:46 PM
sharrack's Avatar
Why was the intake manifold off??
where did you buy your timing belt kit from or did you buy the parts separately?
Old Jan 19, 2021 | 06:54 AM
ptf1496's Avatar
Manifold was off because I also replaced valve cover gaskets, intake gasket, vacuum hoses and fuel injectors at the same time I did the water pump, thermostat and timing belt.
Inzane121
13
Dec 21, 2020 10:45 AM
ghostmoney
Oct 20, 2014 11:21 AM
y2kltdsport
Aug 30, 2009 11:03 AM
quattro
15
Jul 5, 2006 04:01 AM
joe d95
Mar 27, 2004 09:31 AM
