lining up timing belt marks
Old Aug 22, 2009 | 10:18 AM
y2kltdsport's Avatar
hi guys I'm in the middle of the t/b w/pump job, putting on t. belt,I am at tdc have cams centered on their marks up top as well as crank mark lined up, my question is this, I lined up the belt perfect with the factory "L" "R" marks when it wraps around down to the crank, do I leave the crank lined up on the mark or do I turn it a little so it lines up with the mark on the belt??? hope this is clear enough thanks for your help Mike
Old Aug 22, 2009 | 01:15 PM
eric-the-red's Avatar
If the teeth line up with the crank then I wouldn't worry too much about the painted mark on the belt. I've found the best way is start with the crank, then stretch the belt as much as you can by hand and put it on the driver side cam. Then stretch some more and put it on the other cam.
Old Aug 22, 2009 | 07:01 PM
toppppp
Old Aug 23, 2009 | 04:52 AM
noahrexion's Avatar
Start with the crank, then cams, idler and then tensioner. Sometimes its quite difficult for some to do the tensioner last: easiest to leave the idler semi-loose and then do the tensioner, then finish with the idler.
As long as the teeth on the belt slip into the crank pulley and the marks on the cams are close to perfect (some belts are marked a bit off and some dead on) then you are fine. If you are off ANYwhere it will be visibly noticeable. As long as your crank is aligned properly and your cams are aligned properly and the belt fits, you are golden.
Make sure all the pulleys, teeth are clean and oil/coolant free give it a few revolutions and double check your timing marks and then put it all back together.
Old Aug 30, 2009 | 11:03 AM
eddieleephd's Avatar
x2
I definitely found it easier to start at the crank and go counter clock wise!
the real bastard is removing that dang ac compressor!
I lined up the marks and got it all tight then turned the engine over a few times with the igniter disconnected brought it back to tdc and checked
"I believe the cog is marked for the belt and the fly wheel is marked for tdc on the timing mark!"
icentropy
Sep 16, 2020 02:47 PM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
