Rear heat hose size?
Old Dec 4, 2019 | 08:34 AM
fierohink's Avatar
The metal lines for my rear heat have rusted thru. I want to run rubber hose as a temporary fix.
What size hose fits the barb under the front passenger seat?
Old Dec 5, 2019 | 08:50 AM
Malcolm99's Avatar
if i recall it is 3/8", but you could just check in the engine bay as it would be the same barbed nipple and easy to access, I hear that the 2000+ got SS rear heater lines that should still be good if you find a donor at the wreckers, another option i've seen people use is copper 3/8" propane/NAT gas lines, flexible and should also last the life of the vehicle.
Hilux808
Jul 8, 2020 09:09 PM
az4x4runner
Sep 4, 2019 10:42 AM
mussy01
3.4 Swaps
10
Mar 21, 2013 09:22 PM
Jin_Chris
11
Oct 5, 2009 07:26 AM
Jin_Chris
Aug 14, 2009 03:40 AM
