Found my next mod
Old Jul 15, 2020 | 05:38 PM
Zcostilla's Avatar
Found my next mod
This is not expensive, and pretty practical and should be easy to duplicate for the 4Runner: https://expeditionportal.com/forum/t...your-wj.18969/
Old Jul 15, 2020 | 05:41 PM
5 Fists's Avatar
That is pretty cool, would be really handy to just pop those out.
Old Jul 15, 2020 | 07:41 PM
fierohink's Avatar
2nd gens have a similar mod where you replace the bolt with a bolt run from the underside of the truck and then the seat hinge is held down with wingnuts.
Old Jul 22, 2020 | 10:54 AM
RustBucket's Avatar
My solution to this was to replace the bolts with studs. It's easy to pop the seat bottom brackets back onto the stud and run a nut down onto it. Much easier than aligning a bolt each time.
Old Jul 22, 2020 | 06:04 PM
Jomoka's Avatar
I just unbolt that seat bottom. Takes about 3 minutes. Then there's no bracket sticking out on the floor.
Old Jul 23, 2020 | 03:45 PM
RAD4Runner's Avatar
Nice mod.
XTerra's came with readily-removable seat bottoms so you can leave then at home.
I removed mine on my first-gen 4Runner and sold them. Those things are unnecessarily heavy at 15 pounds each just to support a butt. Now my head barely touches the front seat backrests when pushed all the way back, and feet barely touch the closed tailgate. I now use thick, firm foam for the seat bottoms in rare cases I have rear passengers. The foam double as my sleeping pad when sleeping in the back.
Old Dec 2, 2020 | 07:28 AM
Ritzy4Runner's Avatar
This going to be another "Mod for Dummies" on my 4runner!
Old Dec 2, 2020 | 08:48 AM
rattlewagon's Avatar
That is pretty handy.
White SR5
23
Oct 1, 2004 04:41 PM
L33T35T 4Runner
7
Jun 27, 2003 12:13 AM
