97 4Runner Limited Intermittent Wiper Malfunction
Old Feb 2, 2021 | 12:05 PM
charlesml3's Avatar
Gang,
I'm struggling with this one. 1997 Limited. Intermittent wipers have been working perfectly for years. A few weeks ago, the intermittent function started to go. Sometimes the delay was correct. At other times, it ignored the delay entirely and just went on steadily.
Now it ignores the intermittent setting entirely. The first notch is Intermittent, the second is on. There is no difference between those two anymore. The next notch is fast. They do speed up when set to "fast." The washer function works fine.
I have replaced the entire switch/stalk assembly. No change at all. It seems like there should be some kind of relay/delay module somewhere but all of the Google searching I've done has revealed nothing. When it was working I could hear a distinct "click" of a relay somewhere back there that was closing to activate the pulse. Now no click.
If anyone has any idea, it would be much appreciated.
Thanks!
-Charles
Old Feb 2, 2021 | 04:11 PM
fierohink's Avatar
Send me a PM with an email address and I can send you the full electrical manual for the truck.
Old Feb 16, 2021 | 07:23 AM
charlesml3's Avatar
To close the loop on this one: It was the wiper motor.
I think technically it was the switches inside that determined the position but I could only replace it at the motor level, switch bank included. At any rate, replacing it fixed the issue. The remanufactured motor was about $100.
-Charles
zombie_stomp
Oct 25, 2015 11:46 PM
slacker
Mar 4, 2009 09:04 PM
kenaniah
Aug 22, 2007 12:17 PM
michalik_piotr
May 14, 2007 06:52 AM
centraline
Feb 26, 2005 08:03 PM
