Brake swap
Old Mar 12, 2005 | 08:17 PM
desert whomper's Avatar
Brake swap
would it be possible to swap my 2x4 pickup brakes with tundra calipers, rotors and pads?
Old Mar 12, 2005 | 08:21 PM
superjoe83's Avatar
i really doubt it, completely different suspension/caliper mounting design
Old Mar 12, 2005 | 08:41 PM
what if i made a whole new spindle? if i could mount them could i get them to fit? also would hte bolt pattern be the same and if not could i take it to a machine shop to have it redone?
Old Mar 12, 2005 | 08:54 PM
superjoe83's Avatar
well, the tundra uses a non serviceable type wheel bearing and the rotor slides over the wheel studs, while the 95 and older trucks use a rotor which is bolted to the back side of the hub, the only way to tell would be to get both trucks side by side and start comparing things, BTW, tacos and 3rd gen runners use the same type of brake setup as the tundras, except that the rotors are smaller on the tacos and 15" wheel runners
Old Mar 12, 2005 | 09:49 PM
ok, if anybody has pics that would be cool, ill go to a junk yard and take measurements from a taco or 4runner. i would just like to have some really good brakes
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
