OME lift quick ?
Old Mar 9, 2005 | 07:31 PM
RyanCrotty's Avatar
Question OME lift quick ?
ok im ready to order after all the research and im going with the OME lift , its going on a 98 limited and im going with the HD springs and shocks, is that all i need , will the front look like it is sagging , do i need any type of spacers for up front , Do i need to order anything else besides the springs and shocks
Thanks for the help , i know this has prolly been asked a million times
Old Mar 9, 2005 | 08:10 PM
spiff's Avatar
Diff drops
You may also want to consider some diff drops for the front to help the CV angles. The front will sag over time, mine did. I had 2.5 inch of lift now i think its more like 2 or a little less.
Old Mar 9, 2005 | 08:50 PM
Mickdady's Avatar
You will need an e-brake extension bracket. I would also suggest a panhard bar drop. I just did my OME lift tonight with all the pieces mentioned in my signature. Oh, a set of extended quick disconnects are a good idea too. I am amazed at how much the front sway bar hurts downward travel.
Good luck
nvdesertrunner
May 11, 2020 08:18 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
