Installing new fule filter
Old Mar 7, 2005 | 06:27 PM
Eneas28's Avatar
Installing new fuel filter
I'm about to change the fuel filter in my '95 4runner V6 and also the pcv valve and O2 sensor does anybody have any tips before instalation.
Old Mar 8, 2005 | 12:43 AM
Tacoma Dude's Avatar
Fuel filter:
Unscrew the gas cap before you start and make sure you don't have any open flame or sparks anywhere. You might want to do this outside or with a bucket nearby - you WILL dump some gas on the floor.
PCV:
If it's old the grommet around it can be as hard as rock. I had a hell of a time removing the PCV out of my 1st gen and ended up replacing the grommet. A couple squirts with WD-40 was all I needed.
O2:
Actually before you start the whole thing, disconnect the battery. Make sure whatever you disconnect is NOWHERE near the battery. An errant spark with fuel on the floor could be bad.
That's what I think anyway.
Old Mar 8, 2005 | 11:27 AM
Eneas28's Avatar
thanks Tacoma Dude I'll start this weekend.Will keep up to date.
Old Mar 8, 2005 | 11:56 AM
leiniesred's Avatar
2 words for the fuel filter thing.
Crow's foot wrenches
(OK, so it is 3 words)
Anyway, it gets kinda cramped up there by the torsion bars and stuff. If you can't get things loose with your flare nut wrench, you can use a crow's foot with a long extension so you can put some power to it with the breaker bar.
This is what it took on my 89. YMMV.
Toyota dealership: What do you need a fuel filter for?
Me: Well she has 129,000 miles on 'er. Probably due for a change.
Toyota Dealership: We change the fuel filter every time we change the ENGINE.
I ended up changing it at 236,000 miles. Runs the same.
Old Mar 8, 2005 | 12:09 PM
I had about 148K on mine when I changed it and I could immediately feel the difference.
Of course, it was a FRAM that I replaced...
Old Mar 8, 2005 | 12:13 PM
3.4v6's Avatar
the fram one for my 01 taco is a little bit bigger that the stock toyota one. id get teh OEM fuel filter is possible.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
pyramid
Jul 30, 2015 10:05 AM
calderp
Jul 27, 2015 09:58 AM
ddg71
Jul 24, 2015 01:24 PM
jjrbus
Jul 23, 2015 05:05 PM
