Pull both heads at same time.
Old Mar 10, 2005 | 07:12 AM
whays's Avatar
I have a suspicion that my 3VZE heads are going to have to come off here real soon. Has anyone hear pulled off both heads at the same time while leaving the exhaust mani's and crossiver still connected. Then I could mess with all of those nasty bolts on the workbench. If not that approach, I'm thinking that pulling the engine, then removing the crossover etc... Might be a little easier than getting pissed off at all of the close quarters rusty fasteners. Any thoughts or comments are appreciated.
Bill
Old Mar 10, 2005 | 10:17 AM
whays's Avatar
that's here and crossover
Old Mar 10, 2005 | 05:20 PM
whays's Avatar
Anyone?
Old Mar 10, 2005 | 05:26 PM
DudeBud's Avatar
it can be done should have two people when lifting them off unless you are superman
Old Mar 10, 2005 | 05:59 PM
dwh91102's Avatar
You can't unbolt the manifolds from the heads and get them off without unbolting the crossover, unless you pull all the studs out of the heads
Old Mar 10, 2005 | 06:54 PM
wrenchmonster's Avatar
9 nuts. 6 on the cross over and 3 for the actual pipe coming down off the left side. It's not difficult at all, just spray them down well and let them sit overnight. If you happen to break something, oh well, you'll have the manifolds on the heads when you get them off. You can deal with anything broken on the bench. what you are talking about doing is possible I suppose, but why?
-Wrench
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Poncho0206
Jul 10, 2015 06:21 PM
