99 "Tallest" Spring Part Number
Hey All,
I was wondering if anyone has the '99 Tallest Spring P/N?
I have searched and can't seem to find it. I also have searched TRDparts4u.com and think that I have found them, but I want to make sure.
Thanks in advance.
Mark
Thanks in advance.
Mark
Been going back and forth between the OME 881/906 combo with the comfort shocks, but the entire setup would be more costly than just swapping out my PP 1" lift springs with tallest 99 springs. This is because I already have a relatively new set of Bilsteins on the front to match the older ones in the rear. The PP springs with billies are just too harsh for me. I need something that can handle the SoCal roads (pretty much suck).
Front RH: 48131-35400 - Is confusing because it says 2 applications, 1 is 1999-2002, and the other is 1996-1998 in mechanical catalog, 1 application in collision (1999-2000), and 1 is OEM (no years)
Front LH: 48131-35350 - Looks right, only one entry in Collision and OEM (1999-2000)
Rear RH/LH: 48231-35200 - This one is for non 16" wheels. The way I understand it is that the tallest have 16" wheels.
Any comments / suggestins?
Thanks to everyone in advance!
Mark
BTW, have you looked into the OEM pricing? I remember I was going to get OEM rear leafs from the local dealership and they quoted me $550. EACH!!!
EDIT: Looks like they're ~$90 on trdparts4u. Not as bad as I thought. The OME springs are actually a little cheaper than that, though.
If the ride is too harsh, it's more likely your shocks than your springs. Your best bet is to go with the OME comfort shocks.
Mark
on 48131-35400, the EPC says it's for July 1998 to Aug 1999
on 48231-35200, the EPC says it's for July 1998 to Aug 1999 SR5V, SR5B RZN185/VZN185
there's 48231-35210 which is for also for the same time and says RZN185/VZN185 with 265/7016 tires
Thanks,
Mark
This is what showed up when I ordered mine...
FR Springs - Blue / Yellow (48131-35400) Passenger Side
FL Springs - Blue / Pink (48131 - 35350) Driver Side
REAR Sprigs - Yellow / Red (48231 - 35210)
Thanks for the part numbers. 2 of the 3 match what others have said, so looks close.
Quick question - Where did you order you new springs from? Where did you get the part numbers? Are you driving a 99 or something and made the switch?
Just trying to make sure I get the right parts.
Thanks,
Mark
I'm driving a 2000 SR5... my original shocks/springs were pretty worn out and these seemed like a good replacement.
I'm actually going to post the 99 rear coils in the classifieds, decided to go with 906s in the rear to give me a little extra lift.
-batsoff
cyclist231
Jul 7, 2015 12:56 PM
1999, 35210, 4813135350, 48231, 4823135200, 4823135210, 4runner, coil, front, highlander, shocks, sport, spring, tallest, toyota, tranny, vzn185
