what size diff gear to put in?
Old Feb 26, 2009 | 05:36 PM
quickshot's Avatar
i have a 97 tacoma with a 3rz and all i have done is a 3'' lift, 32'' bridgstone dueler mt and a borla muffler. im gettin around 14-16 mixed and was wondering if i changed the diff gear could i do better?
sorry im a noob i dont know much but i just think my truck is capable off a little better then 14. also what size should i get and what is stock? thanks
Old Feb 26, 2009 | 05:45 PM
GenXr's Avatar
You've probably lost a little mpg with the 32" tires but your speedo is likely displaying a slower than actual speed and also racking up less miles on your odometer...probably by the ratio of your stock tire diameter to 32" tire diameter.
Check your actual speed/distance with a GPS unit then use those reading to determine your fuel consumption. After correcting for speedometer/odometer error, you're probably not getting quite as bad fuel consumption as you think.
Now to answer your thread title specifically, you need 8.4" gear sets in the back and 7.5" gear sets for the front of your truck. You could go with 4.88 gears with 32's but you'll rev a little high on the highway but notice more power in town. 4.56 gears will help also, they will be a better improvement over your stock 4.10 gears. 4.56 gears are ideal for 31" tires, and your 32's aren't too much bigger.
Old Feb 26, 2009 | 08:07 PM
3w41d's Avatar
No
all toyota rear differentials are 8 inch
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Feb 26, 2009 | 08:41 PM
crolison's Avatar
Originally Posted by 3w41d
No
not all toyota rear diffs are 8 inch, land cruisers aren't 2wd pu's arent
but the gears you need is the taco 8.4 (even though its 8", always known for 8.4), and 7.5 rev rotation for the front.
I'd go with 4.88's, you'll probably wan't 33's down the road, and this will allow you to have some serious grunt on 32's and perfect for 33's. If i didn't find my 4.88 thirds, i would have gone with 5.29's will still end up with 5.29's though. If you ever thought about lockers, this is the time to do it, while you have all your junk out and getting worked on.
Whatever123
Sep 30, 2015 12:12 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
