Problems with multi-mode 4wd 99 4runner ltd
Old Feb 21, 2009 | 01:54 PM
Greg_Canada's Avatar
Hey guys, i've been searching with no luck on this issue. I found a thred by 99SC4runner with good info, but it isnt the same problem i am having.
My truck is a 99' 4runner 3.4 auto ltd with the multi-mode 4wd.
I cannot get it in 2wd. It makes AWFUL gear grinding noises and clunks.
I can use it in AWD, 4HI, or 4LO, but i cannot for the life of me get it in 2HI. Id say, once out of a hundred tries, it pops into 2HI.
It's not the front differential switch.
I'm thinking it's the actuator not moving all way way, as it moves, but not all the way out of gear. It sounds like is moves 80% of the way.
Anyone else have this issue / ideas? Would it be OK for me to take the actuator out (would there be installation set-up / clocking errors?) and lube it?
Thanks,
Greg
Old Feb 21, 2009 | 01:57 PM
rock slayer's Avatar
is the problem in your tranny or front diff??
Old Feb 21, 2009 | 04:54 PM
Transfer case.
Old Feb 21, 2009 | 05:00 PM
oh yeah thats what i ment i knew it wasn't tranny. does it go in if you back up a lil?? i know its a stupid question but thats how my buddy had to do it!?
Old Feb 21, 2009 | 06:05 PM
The issue is the electric motor isnt going all the way forward. if i move the truck it sounds like it wants to explode....
Old Feb 21, 2009 | 06:30 PM
Godzilla's Avatar
Maybe your centre diff lock sensor? Maybe it is not "seeing" when or not you are fully in 4wd/2wd. That is where I would start, since it is the cheapest.
Old Feb 23, 2009 | 08:35 AM
Bumpppp
Old Feb 23, 2009 | 03:42 PM
Godzilla's Avatar
Best thing to do is to test all your sensors and your actuator to try and identify the problem. Cant diagnose anything further without more infro than just a clunk noise.
Old Aug 7, 2009 | 08:49 AM
The oil was dry! Annihlated the t-case! Geeezzz check your oil levels!!!
Old Aug 7, 2009 | 10:01 AM
brian2sun's Avatar
What are you guys talking about a center diff... And a T-case? AWD, 4HI, and 4LOW all in the same '99 4Runner? I'm missing something..
...Nevermind, I get it. I didn't realize the limiteds came w/ 4x4 and AWD.
Old Aug 7, 2009 | 10:08 AM
badattitude's Avatar
Starting with some 1999 runners and later; the 4WD system included a center diff that allows better 4WD use on hard surfaces. Using AWD (by pressing the 4WD button) allows the front drive shaft and rear drive sharft to spin at different speeds. I'm not sure if these trucks have the same 4hi as the previous models. I know 4lo and 2wd are the same.
t-Case is transfer case, all 4WD models have them.
Old Aug 7, 2009 | 10:28 AM
brian2sun's Avatar
Thanks for the explanation badattitude, I didn't know they did the AWD thing as early as 99. I also thought it was AWD or 4x4, not both! I'm learning...
Do the Highander Editions/Sport Editions have the AWD too? Or just the limiteds?
Old Aug 7, 2009 | 10:45 AM
CYi5's Avatar
Just the limiteds, hard to beat a truck that has AWD, 4hi, 4lo, 2wd, and e-locker.
Old Aug 8, 2009 | 06:34 AM
naksukow's Avatar
just limiteds for 99-00, then all 4runners got multimode.
Old Aug 17, 2009 | 01:03 PM
anniesball's Avatar
Multi-mode 99 Limited
Did any 99 Limited with Multimode 4WD have 5 speeds? I would love to convert my 02 to a 5 speed, but don't want to give up the AWD.
GreenLion
Jun 7, 2021 10:49 AM
toyota32
Jul 6, 2015 05:42 PM
bowhunter1640
18
Jul 5, 2015 03:30 PM
CJ94yota
Jul 3, 2015 10:14 PM
