automation transmission problem...need help!
Old Feb 26, 2009 | 11:09 AM
linkovich's Avatar
Specs: 2000 4runner limited, auto, 3.4, 4wd, 118k
So I went and picked up my father in laws little 15ft boat today and was bringing it back to the house. I had to stop and get gas on the way home. When I got back in the car and went to leave, the tranny wouldn't shift out of park. I had to use the little by-pass switch to get into gear. It shifts fine from Reverse to Low, but once you put it back in park the shifter locks up again.
Once I got home I checked the tranny fluid and it was good. I also tried disconnecting the battery for a little while, hoping that might work but it didn't. I have a buddy bringing his code reader over after he gets off work. Anyone have any other ideas or know what the problem might be?
Old Feb 26, 2009 | 11:11 AM
BigBallsMcFalls's Avatar
it's not the tranny per se. if the bypass switch works, then it is the interlock that is sticking
Old Feb 26, 2009 | 11:31 AM
linkovich's Avatar
Makes sense. Any ideas/suggestions on how to fix it?
Old Feb 26, 2009 | 11:33 AM
mt_goat's Avatar
Might check the brake light switch, or I've even heard that sometimes a brake light problem can cause that, maybe related to the trailer light hook up.
Old Feb 26, 2009 | 04:54 PM
linkovich's Avatar
That was it! I guess the trailor shorted out the break lights and blew the fuse. Popped in a new fuse and everything worked just fine. Thanks for the help.
Old Feb 26, 2009 | 04:59 PM
mt_goat's Avatar
Great
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
