misfire on #2.
Old Apr 4, 2021 | 07:38 PM
dntsdad's Avatar
misfire on #2.
97 3.4 4Runner engine
Worked fine. I swapped out the battery and then #2 is misfiring. Noticeable miss when driving under load.
1. Swapped plug 2 and 4. No change. Still misfiring on #2
2. Swapped coil packs. No change. Still misfiring on #2
3. Swapped in a new injector in #2. No change. Still misfiring on #2
Getting spark at #2 plug
Continuity between #2 injector wire and injector plug and ECM
No idea what to try from here other than compression and leakdown tests. I just can't see that going to ˟˟˟˟ from a battery swap but I can't see anything really going to ˟˟˟˟ from a battery swap. Has to be a coincidence.
Any ideas from those smarter than me?
Old Apr 5, 2021 | 05:52 AM
mdh's Avatar
mdh
Bad battery upsetting ecm? Sounds far fetched but if that is the only thing that changed.... I would swap the battery back or at least connect jump leads from old to new battery and see what happens?
Old Apr 6, 2021 | 07:14 AM
fierohink's Avatar
Could the plug wire have been damaged?
Old Apr 7, 2021 | 04:04 PM
sharrack's Avatar
Check the #2 boot as well. Might be arcing on the tube its in. Check the contacts at the coil on the 90 degree connector as well. I've seen green corrosion build up in there.
tracers87
May 19, 2013 05:29 AM
MTTOY
63
May 16, 2010 08:58 PM
DupermanDave
Dec 6, 2009 06:55 AM
team426f
Feb 22, 2007 08:07 PM
jjdeneen
26
Feb 21, 2003 05:48 PM
