Need help need replacement throttle body toyota 3.4
Old May 22, 2021 | 04:52 PM
Chase Forman's Avatar
Need help need replacement throttle body toyota 3.4 manual
I've tried to order a new throttle body and I am unable to source a new 1 the 1 that I have is way too broken to repair. I have tried countless different methods to repair but haven't had no success. Does anyone have any guides or idea of how to hook up the 4 pin throttle position sensor on an automatic throttle body if so I would be greatly appreciative of it. I have access to a machine shop just was hoping someone could help me a little on what I'll need to do
Old May 23, 2021 | 12:07 PM
2ToyGuy's Avatar
Have you checked the local dealership?
If not there, maybe the local junkyard/recovery yard?
Also, the kind of vehicle, ie: Taco, 4Runner, etc, and what engine, ie: 5VZ-FE etc, and what year, would help us out a lot. If you notice, most people on here put all that info in their sig. Makes it so much easier to know just exactly what we're talking about/looking for.
Good fortune!
Pat☺
Old May 25, 2021 | 07:44 AM
Malcolm99's Avatar
Are you trying to use a 4pin Throttle body on a 3pin wire harness and ECU( I do have the setup and test procedure for 4 pin if you need it), you can't use 4 pin TPS without changing the body ECU and ECU and wiring. Most throttle-bodies are completely rebuildable, shaft, shaft seals, IAC, TPS, theres not much to them, so if yours is NFG buy another used one and rebuild it.
Old May 27, 2021 | 04:49 PM
thanks for the advice. found one misposted on ebay. got a good quality used one now my truck runs great and passed deq as of today.
GC river rat
Sep 14, 2018 12:16 PM
kyle9013
May 5, 2012 08:26 PM
1996Tacoma
9
Jun 3, 2011 07:38 PM
4wheel4real
Apr 3, 2009 07:13 AM
corvettelvr73
May 17, 2004 09:44 AM
