Hello, needing help please
Old Sep 7, 2022 | 10:07 PM
65tbirdsteve's Avatar
Exclamation Hello, needing help please
I don't know what I need to do to start a post
Hello everyone, I am in need of assistance. I have a 99 4runner limited When I try to start it, it just turns over. When I press the gas pedal & crank at the same time, it starts but when I release the pedal it just dies. I have an error code of P0120 Throttle Pedal Position sensor switch "A". I replace the TPS & nothing changes. It seems that as I start, the air flaps are closed with no air going in thus starving for air. Has anyone experienced this? Can it be the IAC? Also I see a something that looks like a vacuum switch in line with the throttle linkage. I believe its called a throttle switch. Maybe diaphragm is defected. Please help! Thx, Steve
Old Sep 8, 2022 | 11:49 AM
2ToyGuy's Avatar
Well, according to the FSM, see the attached PDF, there are several trouble-shooting steps you need to take.
Just follow the chart in the PDF. It'll take you right to the problem. Probably
Good luck! Let us know how it goes for you.
Pat☺
File Type: pdf
Old Sep 8, 2022 | 12:17 PM
That's the info I have been looking for. My question is the Throttle/Pedal Position Sensor/Switch the same as the TPS or is there a second sensor that i'm not seeing. What service manual is the PDF from? I would like to order a copy.
An extreme thank you for your help. So far this is the best response I have had. As soon as I fix the problem, I will post the details.
Thanks again,
Steve
conquistador
Jun 13, 2012 09:50 PM
85straightaxleyota
9
May 28, 2010 10:58 AM
mikes19984x4
13
Apr 13, 2009 05:05 PM
Andrey
May 14, 2005 07:13 PM
lerence
Aug 21, 2004 11:00 PM
