Finally cleaned my skidplate PIX
Old Jun 28, 2006 | 08:47 PM
WHORERUNNER's Avatar
I went ahead and changed some fluids, rear diff(ended up going to stealer because bolt was PITA. But I bought some AMSOIL for my T-case & front diff, and did my Mobil 1 oil in motor w/OEM filter. I couldn't believe the amount of crap my skidplate accumulated from changing my oil filters. Finally I cleaned it up and just decided to pull the skidplate off from now on every oil change. W/ air tools it doesn't take much longer.
[IMG][/IMG] take much longer.
[IMG][/IMG]
Old Jun 28, 2006 | 08:56 PM
bigacuralvr's Avatar
Thats about what mine looks like!! I need to hose mine off....so it's sitting against the wall until I find some time to get to it. What did you use to clean it? Dish soap??
Old Jun 28, 2006 | 09:05 PM
Brake clean and some hard scrubbing with a rag, then just wiped it down w/ some WD40.
Old Jun 29, 2006 | 08:57 AM
wouldn't have thought of that...sounds good to me!!
Old Jun 29, 2006 | 09:09 AM
Ironmike4x4's Avatar
What I wound up doing with mine was cleaning them and spraying rubber undercoating on both sides. It was beginning to rust so I wanted to stop it early. If I could do it over I might would go with POR 15 as one member just posted earlier.
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Team420
Dec 30, 2015 01:31 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
