Steering wheels gets stuck
Old Jun 15, 2006 | 12:23 PM
RTdawgs's Avatar
After turning the wheel at slow speeds, my steering wheel gets stuck when attempting to return to center. It does it when turning in either direction, but a lot worse when turning left. I have to pull it back to center, and I can feel resistance at the spot it gets stuck at. Its at the same place each time, about 90 degrees.
Any ideas on what the problem is?
Old Jun 15, 2006 | 12:37 PM
nightsurfride's Avatar
I would raise your rig's front wheels off the ground (lift from the frame) and see if there is any binding or slack when moving the wheels left and right at the tire. If so, pinpoint the problem area. If all seems ok, I would focus on the steering rack. If this problem happens on pavement, based on your description, it sounds like there is binding in the rack. Any noise from the power steering pump? How is the PS fluid? (Frothy, low, dark and/or metalic flakes?)
Old Jun 15, 2006 | 07:12 PM
RTdawgs's Avatar
No noise from pump, fluid is brand new.
Binding in the rack was my first guess, but i was hoping its something less harsh.
Old Jun 19, 2006 | 01:41 PM
RTdawgs's Avatar
Problem solved.
I have rock lights mounted on my frame and I ran the wires up the steering colum into the engine bay. The wires got tangled in the steering column when i replaced the bushings last week. I pulled the wires away from the steering column, zip tied them and problem solved.
fountain
Dec 31, 2015 06:08 AM
Up&Down
Aug 11, 2015 10:04 AM
terminator
Jul 27, 2015 07:13 PM
cars-guy
Jul 11, 2015 07:51 PM
