Old Apr 12, 2016, 08:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Electrical Guides
Print Wikipost
Q replacing O2 sensors. (Replace both?)
Old Jun 12, 2006 | 05:15 PM
OutdoorLiving's Avatar
So I pulled a P0133 today on the way home from work. Had the code cleared and it hasn't reappeared since. All my reading leads me to believe that the O2 sensor needs to be replaced. I figure I'll go ahead and clean the MAF while I'm at it.
I haven't been able to confirm it, but my reading leads me to believe that there are two O2 sensors. Is this true? If I'm to replace one, should I go ahead and replace both?
Old Jun 12, 2006 | 05:39 PM
rocket's Avatar
More than likely, yes. There should be one before the catalytic converter(s), but after the crossover and the other should be after the catalytic converter(s).
I would.
Old Jun 12, 2006 | 06:25 PM
Elton's Avatar
i would do both while your under there just soak the bolts with pb blaster for a few hours
Old Jun 12, 2006 | 08:16 PM
youngbuck's Avatar
I remember reading somewhere that one of them is a lot more likely to go out than the other, and that you might as well just replace the one that goes out. It would be a while till the other one, less susceptable to fail, would go out. Not sure how true this is, but lets see if somebody can confirm it.
Old Jun 13, 2006 | 05:37 AM
midiwall's Avatar
Yes, there is one in front of the cat and one behind it. The front one is there to read the A/F mixture and report the data to the ECU which then adjusts the fuel mixture to get to "Stoich" which is the "optimum" A/FR (Air/Fuel Ratio) of 14.7:1.
The one behind the cat is there to be sure that the cat is doing it's job. It has no bearing on how the engine is running.
Did you happen to search on "P0133". There is a ton of discussion about this.
Anyway... The P0133 is:
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
This means that the ECU doesn't think that the FRONT O2 sensor is providing data in a timely manor. That's a sign of it getting old.
There is NO reason to replace both sensors. Even from a "preventative maintenance" point of view. The rear sensor will run you about $90, the front one for your year is about $130 (I think). Replace the rear one when the ECU complains about it, nothing will happen to the driveability of the truck when it goes, whereas the front one being flaky will turn into poor mileage and/or power.
Old Jun 13, 2006 | 06:25 AM
Thanks for clearing that up for me, guys.
And yes, Mark, I read every single post in every single thread last night that contained "P0133" I just got the feeling that there was more than one, and was curious if it was a good idea, preventative-maintenance-wise to replace both at the same time.
I can pickup an Denso O2 sensor from a local auto parts shop for $141. Or order one from Gadget (urdparts.com) for $8X. I think I'll hold out a while longer and see if I get the check-engine light again soon.
I need to purchase some minor parts from Toyota anyway. Need to replace the clutch spring bushing-thingy (squeeeeeking) and the gasget above the gear box so it shifts a bit easier.
Old Jun 13, 2006 | 06:27 AM
MTL_4runner's Avatar
Mark is right on, except....
If it is a 1998 then both sensors should be an O2 sensor and both should be about $90 from URD.
Only replace the front sensor as Mark suggested.
Old Jun 13, 2006 | 06:52 AM
midiwall's Avatar
Originally Posted by MTL_4runner
Mark is right on except....
Thanks Jamie... I never remember where that cutoff point is!
Old Jun 13, 2006 | 06:02 PM
Popped another code on the way home.
Order placed 2 day from URD. Hopefully mine will survive until Friday.
Old Jun 13, 2006 | 06:32 PM
youngbuck's Avatar
T
I want my truck to shift easier, can you point me to some info on this? I'll do a search, but just in case you got something else...
Old Jun 14, 2006 | 03:25 AM
Sure...
Old Jun 14, 2006 | 07:55 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
It appears from what I've seen and read that the front O2 sensor takes the brunt of failures. I had the one ahead of the cat replaced and figured I'll wait for the one behind to go in lieu of doing both, especially since the later doesn't impact driveability like the 1st one might (my truck actually got better mileage with the bad sensor!). Matter of choice, I suppose.
Old Jun 14, 2006 | 08:00 AM
midiwall's Avatar
It's in hotter gasses, and the ECU is looking for a lot more to go out of kilter than the rear.
...the 1st one might (my truck actually got better mileage with the bad sensor!).
Sounds like the front one was reporting rich, which forced the ECU to run things lean, which isn't always good.
"Driveavbility" doesn't just mean "good mileage". Acceleration, torque, engine life... there's a lot of stuff in there.
Old Jun 14, 2006 | 11:28 AM
Just to add to that.....there are also alot of particulates/unburned hydrocarbons in those exhaust gasses which can deposit/accumulate on the front sensor over time, while the rear sensor stays quite shielded from this effect since the vast majority of these particulates/HCs are burned off in the catalytic converter at very high temps thus it still accumulates, just MUCH slower.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
