rattle somewhere inside the steering?
Old Jun 23, 2006 | 09:47 PM
MONEY_MIKE's Avatar
i got a 97 tacoma NOt sr5,prerunner,or trd, 3"bodylift 30"tires
Well its not a major deal but there seems to be a rattle that sounds like its coming from somwhere inside the steering column. The steering wheel is solid, and its not like its vibrating or anything its just an annoying little rattle.
ANY IDEAS???
by the way im planning on getting an alignment, balance, and new shocks in a couple of days.
Hope i can fix it
Old Jun 25, 2006 | 06:06 AM
Mikey's Avatar
WHen does it do it? I get a rattle somewhere in the front of mine when its cold outside. I think it could be in the column too.
Old Jun 25, 2006 | 10:03 AM
Gerdo's Avatar
If you rock the steering wheel back and forth with the engine off do you here it? If so it could be: outer tierods, inner tierods or wornout steering rack. Have someone rock the steering wheel while you are under the front and listen for the noise. Once you here the noise and hear where it is coming from then put your hand on the parts and feel the noise. You should also be able to muffle the noise with your hand. If it feels like it is coming from the end of the rack/innertie end, remove the band that holds the rack boot and rock again. If it is the rack you will see the rack end move up and down (BAD) (The boot band can be replaced with a Cable Tie.
Old Jun 25, 2006 | 02:43 PM
grimpy's Avatar
I have the same issue... My steering shaft contacts where the shaft enters the inside of the vehicle. Had to do some trimming and pounding of the wall and cover piece... I still have a slight vibration still...
Old Jun 26, 2006 | 12:11 PM
Mikey's Avatar
I forgot to add, that when it's really cold outside (teens) I can feel it in the floor.
Jcrawl94
10
Oct 24, 2015 04:34 PM
donovanloj
Aug 16, 2015 10:07 AM
agrout
Aug 13, 2015 06:12 PM
JHalcyonM
Aug 4, 2015 01:19 PM
voiddweller
Jul 15, 2015 03:56 PM
