Trying to replace my o2 sensor
Old Jun 9, 2006 | 02:34 PM
ajw62428's Avatar
So I went to the dealer to check out the prices for an o2 sensor..holy
found out that I have Cali emissions so of course the price was about $167. He also told me I can't use anything else or i'll get an engine check light so I need to know is that am I stuck using the $167 OEM parts or can I use the Denso aftermarket? I went to the autozone website and found a Denso 02 sensor for my truck for about $135. I'm going to call autozone to see what they says but I want to be sure before I spend the money. Also I know Cali has stricter emissions control but what IS the difference between that and other types of controls? Like is it about how the engine is program to run or is there extra, specially made, part for that? Thanks
'97 4Runner 2WD V6 automatic 3.4L SR5
Old Jun 9, 2006 | 03:12 PM
GREEN4SKIN'R's Avatar
I don't know the answer to your question although I'm under the impression that almost all O2 sensors are pretty similar two wires or four but if you want a good price on factory parts go to partznet.com it looks llike they have them for $106. I've had great experiences with them.
Old Jun 9, 2006 | 03:25 PM
Greedy's Avatar
Also check out urdusa.com, I bought one there for my 99 runner for around $90.00.
Old Jun 9, 2006 | 03:26 PM
Elton's Avatar
denso $92 cali emisson should have nothing to do with the o2 sensor ? http://www.sparkplugs.com/more_info....72619&pid=1789
Old Jun 9, 2006 | 05:19 PM
DoubleZero4x4's Avatar
Cali Truck...Cali O2 sensor. I think $135 for a Denso sounds pretty good. If it were Fed and not Cali, you would be looking at about $90 from URD.
Old Jun 9, 2006 | 05:23 PM
ebelen1's Avatar
No, you're out of luck. I have a Cali-emissioned truck and I need the more expensive part like you. If you go to URD, it will be $189 or so. I wouldn't trust anything but OEM in your/my situation.
Old Jun 9, 2006 | 05:53 PM
Greedy's Avatar
I think they started using the more expensive A/F sensor in 99+ cali emission trucks and had the 02 sensor in all older trucks (cali and fed emissions). I have a 99 federal emissions and it uses the older 02 sensor.
Check this page out and take a look at his rig - 97 2wd 3.4L auto
http://www.urdusa.com/product_info.p...s_id=430006000
I think it's the right one and is selling for $88.99.
Old Jun 9, 2006 | 06:17 PM
MTL_4runner's Avatar
Verify the part number with the dealer using your VIN then order from URD for the best price. I am 99.99% sure they changed to the A/F sensors in the 99-02 4runners and before that both were just an O2 sensor, but best to verify with the dealer first. The 234-9xxx are the A/F type sensor.
Old Jun 9, 2006 | 06:47 PM
ebelen1's Avatar
I didn't notice that his was a '97. You're probably right as I first started w/ URD and mine was the $89 + $90 for the Cali emission one. I do have an a/f sensor as mine is a 99.
Jaime has a good recommendation as I did call the dealer w/ my VIN to make sure I need the more expensive 02 sensor. I did so I still don't have one yet.
Old Apr 6, 2007 | 05:05 AM
icerunner's Avatar
o2 sensor @ urdusa.com for 79.99 (oem denso)
fyi urdusa.com for 79.99 (oem denso) great fricken deal!!!!! Price at the Stealer 149.99!
I'm going to give it a try this weekend I think there running a sale.
moparbay
Mar 10, 2023 03:50 PM
Firefightersink15
Nov 23, 2015 10:32 PM
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
rmill05
Sep 27, 2015 01:43 PM
