Removed front seat, trouble getting it in
Old May 29, 2011 | 12:39 PM
hungryeddy's Avatar
Exclamation Removed front seat, trouble getting it in
i removed my seat and when i tried to put it in the tacks holding the nut broke, it happened on both front bolts. i cant see a way to get in there to re-tack it... on one of the sides i pulled it until the metal of the body opened up and now i can't get either side bolted in. is there a fix to this? any ideas so i can actually ride around with a passenger?
Old May 29, 2011 | 12:47 PM
corax's Avatar
use a hole saw on the side opposite of the weld nut so you can get into the channel that the weld nut is in
Old May 29, 2011 | 01:13 PM
hungryeddy's Avatar
well now i can't because i forced the not through the whole making it bigger... how can i fix this
Old May 29, 2011 | 02:07 PM
Sin's Avatar
Sin
Can you post some pics? It would help to see what your talking about...
Old May 29, 2011 | 03:03 PM
justin_4runner's Avatar
might need to cut out that section and weld in new plate with bolts welded on the back side, other then that use a big washer to keep the bolt from pulling threw when u tighten it down.
Old May 29, 2011 | 06:38 PM
habanero's Avatar
If you're saying what I think you're saying it's a pretty common problem. I fixed mine by drilling a hole through the floor and using a long bolt. Others have done different fixes.
Maybe this thread will help?
http://www.toyota-4runner.org/3rd-ge...ount-fail.html
Old May 31, 2011 | 07:35 AM
hungryeddy's Avatar
Yep this is it
i couldn't find anything in the search. thanks for this.
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
icentropy
Jul 9, 2015 02:12 PM
garagespace
Jul 9, 2015 08:37 AM
ItsJustD
Jul 7, 2015 07:49 AM
