Engine swap info needed
Old May 3, 2011 | 07:03 PM
blair1's Avatar
Ok I have a 1995 Tacoma 4x4 v6 5vzfe with a manual trans. I need to replace the engine and I have found a 1999 4 runner 2 wheel drive v6 5vzfe. Is there anything that will need to be changed to make the donor engine work. Only thing I can think of would be the fly wheel. I have been told the oil pans on 2 and 4 wheels drives are actually the same. Also the donor engine has 80k miles in it so what are some things I should do before installing this engine.
Thank you to all........
Old May 3, 2011 | 07:12 PM
gk5's Avatar
gk5
Sounds like a bolt in affair...... ive swapped a 3.4 into a 92 pu, swapping like motors into a chassis that was originally made for that motor shouldnt be a problem.
Old May 4, 2011 | 05:41 AM
blair1's Avatar
So nothing to change?
Old May 4, 2011 | 07:59 AM
justin_4runner's Avatar
when u get the new motor over look all sensors and make sure they are a direct match. if not replace with yours, they might of changed little things so u might have to use your intake manifolds or things like that, but should be a strait bolt in for block wise.
Old May 4, 2011 | 11:28 AM
blair1's Avatar
what is a decent price to pay for a 99 5vzfe with 80K?
Old May 5, 2011 | 10:10 AM
sdsurfer's Avatar
I started similar thread. See "Darn motor swap"
I hear if auto and manual , may be different wiring from harness.
Stop by my thread and let's merge. I have seen used motors from 500-1200.
Go go go. Let's swap motors dude.
Also is your 95 also 3.4?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
