Engine swap info needed
Ok I have a 1995 Tacoma 4x4 v6 5vzfe with a manual trans. I need to replace the engine and I have found a 1999 4 runner 2 wheel drive v6 5vzfe. Is there anything that will need to be changed to make the donor engine work. Only thing I can think of would be the fly wheel. I have been told the oil pans on 2 and 4 wheels drives are actually the same. Also the donor engine has 80k miles in it so what are some things I should do before installing this engine.
Thank you to all........
when u get the new motor over look all sensors and make sure they are a direct match. if not replace with yours, they might of changed little things so u might have to use your intake manifolds or things like that, but should be a strait bolt in for block wise.
I started similar thread. See "Darn motor swap"
I hear if auto and manual , may be different wiring from harness.
Stop by my thread and let's merge. I have seen used motors from 500-1200.
Go go go. Let's swap motors dude.
Also is your 95 also 3.4?
