How many quarts in trans after flush?
Old May 5, 2011 | 05:54 PM
Bawlzdeep's Avatar
I just had to flush my trans out after the pink milkshake. Now I have the B&M 70264 cooler but think I used way to mush fluid. I refiled with 8Qts and it reads pretty high on the dip stick. The book said 10 so I thought I'd leave 2 to spare. I'm guessing the torque converter didn't empty out. Way to much hugh? Probly should have been like 4Qts right?
Old May 5, 2011 | 07:58 PM
justin_4runner's Avatar
yeah drain it out tell u get it into the right range, u could screw up the trans if u dont, and after driving it for a day check it and make sure its still with in specs. also look in the fsm for the right amount im not sure on how much to flush it.
Old May 5, 2011 | 08:06 PM
skjos's Avatar
http://home.centurytel.net/stevenjac...sh/tranny.html
About 16qts to flush the system. Only about 4-5qts in the pan if you just drain it. When I dropped my pan I had about 6.5qts poured into the bucket.
Old May 5, 2011 | 08:43 PM
raydouble's Avatar
x2
I ended up putting about 4.5 quarts in at my drain and fill.
Old May 6, 2011 | 01:50 PM
Bawlzdeep's Avatar
Thanks, I drained it and put 3Qts back in. Gonna go camping tonight so I'm bringing another 2 qts with to top it off after I get a good op temp reading.
Davebarbier
Nov 3, 2015 03:28 PM
dzldust
7
Oct 6, 2015 05:39 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
puddlepirate
Sep 29, 2015 08:02 PM
tshort48
Sep 27, 2015 01:04 PM
