Removing Old Gasket Material
Old May 7, 2011 | 11:42 PM
BDTB's Avatar
I removed the water pump from my '02 runner, 125k miles, and commenced the brutal task of removing the old gasket material. I got it down to the point where any traces of material you could feel to the touch were gone, but there was still an "impression" of the old gasket in a few spots that I couldn't remove. I used a red Scotch Brite pad with brake parts cleaner. I tried some gasket remover, but it was useless.
How have you guys gone about this?
Old May 7, 2011 | 11:49 PM
justin_4runner's Avatar
use a razor blade or fire brush on a drill wire wheel i guess and it takes off the stuff u are talking about,
Old May 8, 2011 | 04:24 AM
vtbuckslayer's Avatar
the wire wheel is bout the best you could use. beats scrubbin on it by hand anyday!
Old May 8, 2011 | 06:38 AM
Brando338's Avatar
WD 40, and new razor blades all day long. really scrape that surface w/o digging into it.
Old May 8, 2011 | 10:41 AM
javadoody's Avatar
razor blades and carb cleaner
Old May 8, 2011 | 10:50 AM
Mikel1871's Avatar
Yeah, I use a razor(scraper for control) and PB. spray on the PB let it sit for a bout 5 min., then hit it with a scraper.
Old May 8, 2011 | 10:59 AM
ChefYota4x4's Avatar
I used Acetone and a Brass Brillo, .....came right off in 2 minutes without risking scratching that aluminum timing cover.
Old May 8, 2011 | 12:02 PM
wyoming9's Avatar
Red face
I use a 90 degree die grinder with the 2'' pads for aluminum.
Works great The pads for aluminum won`t remove as much aluminum as the pads made for use on steel
Old May 8, 2011 | 01:22 PM
BDTB's Avatar
Haha! Wow, I was reluctant to use a rotary method, so I did it all by hand. That's 3 hours completely wasted. DOH!
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Esibnitsud
Jul 30, 2015 08:19 PM
irritech
Jul 27, 2015 05:15 PM
Snort
Jul 9, 2015 03:58 PM
