02 4Runner Will Not start!!
Old Apr 27, 2011 | 04:32 PM
4runnin2002's Avatar
ok so i know i made the mistake, and washed my engine compartment with the engine off, let dry out for a good day or so. when i went to start it i got a single click from the starter. took the time replacing starter contacts still just a single click. had the battery checked, its good and charged. still nothing, any suggestions?
moderator-move this to the noob section if needed
Old Apr 27, 2011 | 04:39 PM
Swimmerboy2112's Avatar
Bet you got water in the spark plug chambers, happened to me once, pull the plug wire (NOT the plug) and see if there is any water in any of the cylinders, if there is, replace all the plugs.
Old Apr 27, 2011 | 05:38 PM
PismoJoe's Avatar
How did it look inside the starter when you took it apart? If it was really corroded, changing the contacts won't always do the trick. Did you clean the 2 connections feeding to the starter?
Old Apr 27, 2011 | 06:31 PM
vital22re's Avatar
totally a bro
Check and clean your battery terminals. Also, did you leave something turned on and possibly drain the battery.
Old Apr 27, 2011 | 06:48 PM
something stupid. got it fixed!
Moderator-please delete!
Old Apr 27, 2011 | 06:51 PM
prorunner's Avatar
What was the problem? Owning a 3rd gen 4runner my self I'm interested to know.
Old Apr 27, 2011 | 08:08 PM
COAKDawg's Avatar
Yeah, I'm curious too. . . . No worries about it being something stupid. . . . we've ALL done something stupid once or twice.
Old Apr 27, 2011 | 09:09 PM
welllll.....my battery cable was loose, the positive cable needed to be pinched a little tighter and problem solved. silly
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
camdenbuck
Jul 7, 2015 07:33 AM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
