Adjustable panhard
Old May 17, 2011 | 02:56 PM
vegaskurt's Avatar
Adjustable panhard
Thought I would share.
If I did not own a welder, I would of saved the weekend and called Steve at Sonoran steel and ordered his, but I have to do things the hard way.
This is what I built last sunday.
Parts:
1" of 1.75od .120 wall DOM for a bushing sleeve
1 leaf spring bushing, poly, from an 80s jeep.
1 9/16" bolt (3")
1 7/8" threaded stud from ballistic fab
1 7/8" tube adaptor (ruff stuff or ballistic fab)
2.5 feet of 1.5od .120 wall DOM to sleeve a section of the factory bushing.
I had to cut the leaf spring bushing down to size to fit the super small width of the factory brackets on the axle. Then I had to drill out the existing 12mm bolt to 9/16" to accept the new bolt.
Pre-assembled
The fun part was taking the chop saw to the stock panhard bar, that was the point of no return. :jester:
Sleeve fits like a glove.
Installed.
I've only put 10 miles on it, but it seems better already. Less play from the new bushing probably helps a ton. As far has centering the axle, I could still push it over 1/2" or so to make it perfect but for now its a lot closer to factory than it was.
Old May 17, 2011 | 03:07 PM
CYi5's Avatar
Get ready to sheer zerks off your driveshaft . May want to clearance your gas tank skid before it's too late.
Old May 17, 2011 | 05:25 PM
vegaskurt's Avatar
Sheared my first zerk off 3 years ago. Took a notch out of the gas tank skid so that would never happen again. So far so good.
Old May 18, 2011 | 09:29 PM
aowRS's Avatar
Nice work.
What rear disc setup do you have? Also, who makes the air bump shown in your pic?
Andreas
Old May 19, 2011 | 03:00 PM
vegaskurt's Avatar
Its the front range offroad full float setup.
The air bump is from FOA. www.f-o-a.com
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
dbollier123
Sep 29, 2015 05:23 PM
potatopants
Sep 15, 2015 06:26 AM
