Advance auto rear 99 springs
Old Jun 4, 2011 | 11:35 AM
mattbatson's Avatar
Are these slightly taller/stiffer than my 97's? I imagine they are made by Moog, or some such...
Does anyone have any experience with them?
I've looked at local junkyards for old 99 rear coils, but no luck in my area...
I have the dreaded rear sag on my 97, and would like to cure the problem.
My stockers have 220K miles on em too
thx
Old Jun 4, 2011 | 08:39 PM
ToyoMoCo's Avatar
Not really sure if the moog coil for a 99 would be any different than a moog coil for a 97 I am guessing that they are all the same rear coil. The 99 was the only year that was taller so I don't see moog making a special coil for 99 models... I have a a 99 and to me it still seems to sag. I have read about people using 99 front coils (which are a little taller than other years) paired with an old man emu 906 coil, this combo seems to sit level. If you get the 906 and run it with the 97 front coils you might have a slight rake. Best bet to get the 99 coil is go to a dealer but the ome 906 coil may be cheaper from toytec.
Old Jun 5, 2011 | 04:36 AM
mattbatson's Avatar
the toytec ome 906 springs for the rear are a no go.
they said it will cause a lot of rake with stock front springs...
Hopefully somebody on here has bought the moog rear springs and can chime in on how effective they were.
I could go to the dealership for 99 rear coils, but I assumed that they would be really expensive...might give them a call for a price.
I could also replace all of the springs with the toytec stuff, and get a 1.5 to 2 inch lift. I just didnt need a lift for what I do, and didnt want to have to mess with the front springs also if I didnt have to.
but if this is my best option, then that is what I'll do
Old Jun 5, 2011 | 07:15 AM
aowRS's Avatar
Matt,
I installed new '99 coils (front & rear) back in '03 or so. At the time, I believe I paid around $60 each from Texas Toyota.
I wouldn't mess with unknown coils from a car parts store....
Andreas
Old Jun 5, 2011 | 02:29 PM
ToyoMoCo's Avatar
It's also possible to get the 906's and pull the conical bump stop out which would reduce the height by a 1/2".
Old Jun 5, 2011 | 02:38 PM
ToyoMoCo's Avatar
Here's a link the 99 rears were way cheaper than I thought.
http://parts.camelbacktoyota.com/par...layCatalogid=0
Old Jun 9, 2011 | 07:57 AM
mattbatson's Avatar
Originally Posted by aowRS
Matt,
Andreas
hmmm, my local dealer is selling them for 100 a piece...?
Old Jun 9, 2011 | 07:59 AM
mattbatson's Avatar
is that a dealer? are those factory parts?
thx
Old Jun 9, 2011 | 08:14 AM
Mauzer's Avatar
The 97 4Runners didn't have the conical bump stops, Toyota didn't start using them until half way through 1998
Old Jun 9, 2011 | 08:54 AM
mjwalfredo's Avatar
The 97s didn't have the conical bumpstops from the factory but if the tsb for the rear springs was done then you will have them on a 97.
Old Jun 9, 2011 | 10:01 AM
ToyoMoCo's Avatar
thx
Yeah those are oem springs from an online dealer, if you look up toyota oem parts in google you will get several online dealers they all seem to have the same parts lookup catalogues.
Old Jun 9, 2011 | 10:57 AM
mattbatson's Avatar
Matt,
Andreas
called texas toyota and they want 91 bucks per
Old Jun 9, 2011 | 11:00 AM
mattbatson's Avatar
Ok, just making sure these are toyota factory springs and not something else...the manufacter and material used in making coil springs can greatly affect their performance and longevity....so i wanted to be sure
Old Jun 9, 2011 | 11:14 AM
mattbatson's Avatar
really appreciate it, you just saved me like 40 bucks.
I called my local dealer and told him about that dealer in az, and he said they could match that price.
thx
Old Jun 9, 2011 | 12:37 PM
ToyoMoCo's Avatar
Good info to know, I had no idea, I own a 99 and a 97 4runner and the 97 has them. Was the tsb related to rear end sag?
Old Jun 9, 2011 | 12:38 PM
ToyoMoCo's Avatar
thx
Cool, I hadn't thought about trying to get a local dealer to price match. What did the local dealer want as far as proof of the online price?
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
toyoda8488
Jul 5, 2015 10:18 PM
