Turn Signal Problems
Old May 19, 2011 | 06:51 PM
CTRJ's Avatar
I am in the middle of a rather lengthy road trip and this morning my turn signals started acting up.
Here are the symptoms--
97 4Runner
If I use the left turn signal, both left and right signals come on (like using the hazards).
If I use the right turn signal, all is fine.
If I use the right turn signal and step on the brake, the right signal comes on solid.
The hazards work fine.
I'm not sure if it is related, but I am towing a trailer and it does this with the trailer wiring plugged in and unplugged. It also has been raining and snowing a lot over the last couple of days.
Suggestions???
Old May 19, 2011 | 07:31 PM
tunnelmotor99's Avatar
Most likely one of your turn signal bulbs is shorting out, I've seen it happen several times. Take a new bulb and swap them out one at a time until the problem goes away, check the tail/brake bulbs too. Good luck and keep us posted!
Old May 20, 2011 | 03:58 AM
iselloil's Avatar
My pickup did this.Ended up that a wire abovr the rear axel, passenger side was rubbing the frame and ground.Never blew a fuse.
Sleaker
Aug 26, 2020 06:03 AM
gary4runner
Sep 24, 2015 12:53 AM
rushw
Jul 18, 2015 01:46 PM
dpridgeon3
Jul 9, 2015 01:18 PM
karbin
Jul 5, 2015 11:37 PM
