Turn Signal Problems
I am in the middle of a rather lengthy road trip and this morning my turn signals started acting up.
Here are the symptoms-- 97 4Runner If I use the left turn signal, both left and right signals come on (like using the hazards). If I use the right turn signal, all is fine. If I use the right turn signal and step on the brake, the right signal comes on solid. The hazards work fine. I'm not sure if it is related, but I am towing a trailer and it does this with the trailer wiring plugged in and unplugged. It also has been raining and snowing a lot over the last couple of days. Suggestions??? |
Most likely one of your turn signal bulbs is shorting out, I've seen it happen several times. Take a new bulb and swap them out one at a time until the problem goes away, check the tail/brake bulbs too. Good luck and keep us posted!
My pickup did this.Ended up that a wire abovr the rear axel, passenger side was rubbing the frame and ground.Never blew a fuse.
