Replacing time belt on 3.4L.
Old Jan 29, 2009 | 04:20 PM
Question Replacing time belt on 3.4L.
Hello all,
Does anyone know the torque spec for the camshaft pulley bolts? Also, which idler pulley is number 1? Is it the top pulley between the two camshaft pulleys or is it the one just below the water pump?
Thanks,
______________________
1997 4runner
Old Jan 29, 2009 | 04:28 PM
skjos's Avatar
I believe the information you need can be found here:
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old Jan 29, 2009 | 05:20 PM
Thanks, but it does not say which idle pulley is number 1 and which one is number 2. They also did not remove the camshaft pulleys so there is no torque spec.
I have been searching for this info and I can't find anything.
Thanks again,
_______________________
1997 4runner 4x4
Old Jan 29, 2009 | 05:43 PM
Mason Dixon's Avatar
i have the factory service manual if you want it, send me a PM
Old Jan 30, 2009 | 05:58 AM
mt_goat's Avatar
Online FSMs: http://www.ncttora.com/fsm/index.html
Old Jan 30, 2009 | 06:07 AM
mrdoug's Avatar
The short answer is 81 ft/lbs... but get the FSM, it's like having a cheat sheet for working on your truck.
No 1. Idler pulley is down by the waterpump
Last edited by mrdoug; Jan 30, 2009 at 06:29 AM. Reason: corrected mis-information
Old Jan 30, 2009 | 06:24 AM
mt_goat's Avatar
Originally Posted by mrdoug
The short answer is 217fl/lbs... but get the FSM, it's like having a cheat sheet for working on your truck.
Hi Doug! I know the crank bolt is 217ft-lb for the 5vz but is the camshaft bolt 217 too? At first I though he was asking about the crank bolt.
Old Jan 30, 2009 | 06:27 AM
mrdoug's Avatar
Doh!.. crap. I missed that. I see torque specs on a timing belt change and automatically go to the most often asked spec for the pain in the ass bolt.
Editing my original answer... Thanks for catching that Dale.
If for nothing else, getting the FSM keeps you from getting bad info from people who mistake your question (like me).
Old Jan 30, 2009 | 06:42 AM
mt_goat's Avatar
You're welcome Doug, I almost did the samething myself.
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
