fog lights
Old Jan 29, 2009 | 09:28 AM
y2kltdsport's Avatar
fog lights
Can anyone reccommend a good set of foglights that will work in the stock location?? 2000 ltd runner, thanks in advance Mike
Old Jan 29, 2009 | 12:19 PM
scuba's Avatar
Hella micro de's I believe is the name...
Old Jan 29, 2009 | 12:25 PM
okie81's Avatar
X2, they have a good kit out there that comes with all the brackets/components you need, as long as you have a stock location for them in the bumper
Old Jan 29, 2009 | 08:19 PM
thanks guys they look like they will work
Old Jan 30, 2009 | 05:28 AM
Rock Slide's Avatar
Do a search on here for Hella Micro De...you'll find a ton of info on them and places to buy. You can even retrofit in a set of HID bulbs if that's your pleasure.
Old Jan 30, 2009 | 06:45 AM
mkgarrison5's Avatar
this maybe a stupid question but can the plastic valence (sp) from a 02 4 runner fit a 02 tacoma?
Old Jan 30, 2009 | 10:48 AM
wunbigtacoma's Avatar
looking for a 99 up factory 4 runner fog light. thax matt
Old Feb 2, 2009 | 05:29 AM
bumping it up... need question answered please.
Old Feb 2, 2009 | 08:16 AM
Maine Runner's Avatar
If you have a SR-5 or Limited 99-02, a replacement to the factory fog lights is the Hella's.
It has a different bracket but is specific to the 4Runner.
Take a look at Hella Micro DE's for the 4Runner
I know several members who either replaced theirs or installed them on their SR-5. You can either plug into the factory harness and use existing stalk switch or if an SR -5 use their dash switch. Good instructions.
Old Feb 2, 2009 | 08:47 AM
Old Feb 2, 2009 | 01:00 PM
pfdaxe's Avatar
Nope.....
Old Feb 8, 2009 | 07:34 PM
spaber05's Avatar
if you do go with those hellas, I had problems with water getting in so once i got them in good working order, I put a little silicone around the rubber seal on the back end and that seems to have solved the problem. Granted, the truck as been swimming a few times haham, still, not a bad idea if you ask me
Old Feb 8, 2009 | 07:47 PM
okie81's Avatar
True, the front tires throw water onto them and burn the bulbs. I made some custom splash guards that may help....
https://www.yotatech.com/forums/f2/4...-style-164664/
If not, there's a link in there where someone has fabricated some more professional-looking splash guards.
Old Feb 9, 2009 | 12:49 PM
Rock Slide's Avatar
Your version should work just fine.
Otherwise, there's this one: https://www.yotatech.com/forums/f2/3...shields-58066/
Old Feb 17, 2009 | 08:50 PM
are the hellas better than the factory ones? I found this set that is identical brackets and everything,http://cgi.ebay.com/ebaymotors/99-02...6028QQtcZphoto don't know about the quality, with the hellas I would need new brackets right or can the old ones be used?
Old Feb 17, 2009 | 11:08 PM
kernel's Avatar
The set mentioned by Maine Runner is a good buy. I picked it up on Ebay for 100 bucks and it came with everything needed (brackets, wiring, switch).
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
