Gasket
Old Aug 19, 2004 | 09:32 AM
halibut's Avatar
Gasket
I just got a new set of doug thorley headers for my 94 toy 4x4 with 22re
it was used in good condition. The question I have is do I need a special exghaust gasket or can i use a stock one. clean air in take plenum and made
A small difference my gas milage up to 23.4 miles per gallon with corrected milagedue to lager tires. not bad hope get a little more with header. New tail pipe will have to wait a little longer. Just got bfg mudders only got 1 pair working on the other set.
Old Aug 19, 2004 | 11:06 AM
Tacoma Dude's Avatar
Are you talking about reusing the gasket?
Probably not a good idea...
Old Aug 19, 2004 | 12:35 PM
halibut's Avatar
gasket
Let me refrase it do I need a new special gasket or can I use a new oem gasket. Also will Ineed new longer studs and heavey duty flanged nuts for the set up any who has ordered the thorley did the kit come with new studs and nut?
Old Aug 19, 2004 | 12:55 PM
I don't know if this is going to help but when I was going back and forth with LC Engineering they said that everything I needed would be included in the kit. Where are you planning on getting these headers? Summit racing seems to have some pretty good prices.
Old Aug 19, 2004 | 01:00 PM
halibut's Avatar
Have the header on low budget had to get used but in great shape but did not come with gaskets of course or longer studs and nuts.
Old Aug 19, 2004 | 01:04 PM
I can't say that I have the answer about the stock gasket but I've heard a lot of people complaining about gasket issues. Someone threw out the suggestion of going to a copper gasket while someone else mentioned double gasketing.
LC Engineering sells their gaskets for just over $15.
Maybe you should see if Thorley sells their gaskets separately? It's got to be cheaper than OEM.
Old Aug 19, 2004 | 01:41 PM
halibut's Avatar
Just called thorley and asked them the parts says come by and I'll give you one is that great or what. Also asked about nuts we said most peaple reuse the stock ones.
Old Aug 19, 2004 | 01:46 PM
Score for you!
That's some pretty awesome customer service!
Old Aug 19, 2004 | 01:59 PM
halibut's Avatar
will make the trip tomorrow I can also check my milage just cleaned air plenum and added injector cleaner I should be up to 23 mpg [I hope].
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
bootscootboogie
Sep 5, 2015 05:57 AM
Scotto6591
Sep 3, 2015 07:38 PM
scottyg486
Jul 19, 2015 05:34 PM
