How many different belts?
Old Aug 19, 2004 | 08:05 AM
jim1000's Avatar
I have a 1999 3rd generation 4Runner SR5V6 that has 81,000 miles on it.
I am taking it to the dealer for a timing belt and water pump replacement, and am wondering what other belts there are that can/should be replaced at this time?
What other belts would you recommend that I change at this point? What other belts are there on this V6 engine?
Thanks in advance for your help.
Old Aug 19, 2004 | 08:37 AM
blank's Avatar
You may want them to check out your cam belt as those can wear out around 100k.
Old Aug 19, 2004 | 08:41 AM
rimpainter.com's Avatar
(3) other belts can and should be replaced, assuming you have AC.
Originally Posted by blank
You may want them to check out your cam belts as those can wear out around 100k.
Old Aug 19, 2004 | 09:12 AM
jim1000's Avatar
What are these three other belts? Yes, I do have A/C.
Old Aug 19, 2004 | 09:14 AM
Crank -->ALT
Crank --> AC
Crank --> PS / FAN
Something like that anyway.
Just take a look under there, you can see what each one does.
Old Aug 19, 2004 | 10:22 AM
blank's Avatar
oops, read right over 'timing belt' in the first post. ignore...
Old Aug 19, 2004 | 10:25 AM
No problem, I thought that's what you meant, but then I was like say what?
Old Aug 19, 2004 | 10:51 AM
4RUNR's Avatar
Guest
Why replace it at 80? 60K is the maintenance interval.
Old Aug 19, 2004 | 12:00 PM
jim1000's Avatar
Yeah, 60k is the recommended service interval for the timing belt, but keep in mind that this is a Toyota that we are talking about. I would just keep driving it until the timing belt broke, but the local dealership is running a special for the timing belt replacement, so I thought I would do it now while I can get a good price.
60k interval is way too conservative. I think 90k is more reasonable/realistic.
Old Aug 19, 2004 | 12:04 PM
4RUNR's Avatar
Guest
Ahh so you neglected the 60k change
90k is fairly conservative also. Plenty Camrys and Corollas rolling around with 200k on original belts.
Old Aug 19, 2004 | 01:04 PM
jim1000's Avatar
In that case, do you think that it would be a good idea to just keep driving until your timing belt breaks, since it would be a waste of money to change it if your timing belt could be good until 200,000 miles?
Old Aug 19, 2004 | 01:35 PM
4RUNR's Avatar
Guest
If I were to make a bet, I'd bet that even at 120k your original belt will be fine. You live in an area with good weather for all rubber things. Ultimately you need to make the decision if a few hundred dollars now are worth more than possibly being stranded somewhere in the future.
Old Aug 19, 2004 | 02:33 PM
DavidA's Avatar
My dealership said that 90k is good on a 3.4 belt. I am going to wait until then.
primordialbeast117
Dec 19, 2015 12:23 PM
mbomberz1
Oct 9, 2015 07:17 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
