OBD-I Codes
Old Aug 20, 2004 | 11:03 AM
805specr's Avatar
OBD-I Codes
I have a 92' Pickup and I'm not familiar with OBD-I.
Is it possible for the computer to store codes/information without the check engine light coming?
Old Aug 20, 2004 | 11:08 AM
nunsa's Avatar
Yes! The Check connector is under your hood next to your fuse box, grab a paperclip and put one end into the "t" or "te" terminal and the other end into the "e" or "e1", turn the key to on but do not start, a code will flash on the dash, if you have no codes, it will flash real fast, if you have a code, it will flash a 2 part code, example: code 21 would be ** followed by a short pause and then a *, and then the code would repeat itself or start another code!
Good Luck!
* Harry *
Old Sep 11, 2004 | 03:22 PM
805specr's Avatar
Finally pulled the code!
I pulled code 14 which I think is a ignition signal problem. What could cause something like this and what should I check??
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
